LRS shortblock - Mustang Evolution
Old 10-23-2012, 01:40 PM   #1
91notchback's Avatar
LRS shortblock
TH or dream (or anyone with an opinion):
I was lookin at the economy short blocks at Latemodel Resto. They have forged aluminum pistons among other things. They say "cylinder walls are bored minimum for clean up .040-.060. If it needs to go further, a sleeve is installed." Is this normal? Can someone read the ad for me and tell me if this is a good deal for $1700 please?
http://www.latemodelrestoration.com/...Forged-Pistons
91notchback is offline   Reply With Quote
Old 10-23-2012, 01:43 PM   #2
WhiteCobra94's Avatar
That's the block I'm using !!! Love it
Old 10-23-2012, 01:49 PM   #3
ID:	73298   Click image for larger version
Old 10-23-2012, 01:51 PM   #4
I remember you pointing it out to me, and a few people downing it because it was bored so far and sleeved if necessary. From what I understand boring .060 is done all the time and sleeving the block is common.
Old 10-23-2012, 01:58 PM   #5
93slowstang's Avatar
Some people don't recommend using one for a daily driver if its bored more than .030 over. Whitecobra seems to be fine with his so I would say go for it if it fits your budget.
Old 10-23-2012, 02:00 PM   #6
I think when it comes down to boring it , its who and what company does it, and LMR is a good company with all the right machining
Old 10-23-2012, 02:09 PM   #7
I do believe they sell great products. And I do believe they would be fine as whitecobras is. But I don't think I would buy it with plans of forced induction.
Old 10-23-2012, 02:12 PM   #8
That's the thing though. With the fine print that it states you don't really know who's doing it. I don't believe they are doing it themselves. And also not all blocks are equal. Some maybe worn thin at .060 over were others may not. But if they did proper sonic testing procedures to verify they were ok then they probably are. To me there are a few questions left unanswered.
But with that said you have had good luck with it and I haven't read any bad reviews.
Old 10-23-2012, 03:32 PM   #9
There's nothing wrong with my block. I will be on a budget. I just didn't wanna put a trickflow top end kit on a old block. (I will be doing this after the first of the year) Do you think I'd be better off getting my block honed and going from there?
Old 10-23-2012, 03:41 PM   #10
if there is nothing wrong with your block then i would just use it. just have th machine check it out and freshen it up.
Old 10-23-2012, 03:48 PM   #11
Cool. I'll just make plans to do that then. By the calculations TH put up, I planned on using 30# injectors. What size tb and MAF would you think I would need?
---------- Post added at 04:48 PM ---------- Previous post was at 04:48 PM ----------
Sorry for the 20queston thread...lol!
Old 10-23-2012, 03:51 PM   #12
30s should work. im not sure on the sizes for tb and maf. i would guess 70 maf and 65 tb? i would, if you can swing it go with the abaco maf though.
Old 10-23-2012, 03:59 PM   #13
I was thinkin 70tb and 75maf, but I was just takin shots in the dark. Thanks for everybody's help. And I'm sure I'll have more questions before build time. Thanks guys!!
Old 10-23-2012, 04:14 PM   #14
im taking shots in the dark to. i have a carb. lol
Old 10-23-2012, 05:40 PM   #15
True! +1 I plan on keeping my motor N/A!!
Old 10-23-2012, 07:40 PM   #16
Haha that's what I thought too Turbooooooooo!
JayKranz is offline   Reply With Quote
Old 10-23-2012, 11:42 PM   #17
Sybesma07's Avatar
So how much HP will that kit push and what times would you run in the quarter mile with that kit. Do You or anyone else know or have this set up?
Sybesma07 is offline   Reply With Quote
Old 10-24-2012, 04:25 AM   #18
89 coupe's Avatar
It all depends on your set up and $$$!!! But the block and bottom end itself would probably get you 400 to 450 with the use of girdles to be on the safe side. 500 hp + needs to be a special filled block or up grade to 351. Now others my disagree but I'm a conservative when it comes to money and doing it right the first time.
89 coupe is offline   Reply With Quote
Old 10-24-2012, 09:49 AM   #19
Sybesma07's Avatar
I'm just talking about the kit. Basically a stock block with the kit on to. Only a cam in the bottom end.
Old 10-24-2012, 09:52 AM   #20
What is your budget for the shortblock? Onceyou start getting in the $2000-$3000 range there are significantly better options. For instance DSS or any other speed shop/engine builder.
10:49 AM
