Crown Vic motor - Mustang Evolution
Old 10-24-2012, 12:48 PM   #1
Bily Pepp's Avatar
Crown Vic motor
Would a 94, or 95 crown Vic motor fit in a fox body, I have one available for 200, 5.4 police package.
Bily Pepp is offline   Reply With Quote
Old 10-24-2012, 01:44 PM   #2
Lorraine's driver
ab_mach1's Avatar
Are you selling?
Instagram: @ab_mach1
Old 10-24-2012, 03:39 PM   #3
Bily Pepp's Avatar
I might buy it if it'll fit, and I can do it on a budget
Old 10-25-2012, 07:29 PM   #4
Titus Wadicus
svtlx's Avatar
it will b a super tight squeeze. u need a "k-member" from a 96-03 4.6 stang, convert your power brakes to manual cause there is no room for the power booster.
you can buy an aftermarket k-member with shorter motor mounts. the 5.4 will stick up quite a bit out of the engine bay. u may be happier with a 4.6 4v for that application.
anyway.... it will fit and has been done before to answer your question.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-26-2012, 02:27 PM   #5
There's the key. They can be made to fit, but it's not going to be cheap.
03:58 AM
