Air Filter Differences ? - Mustang Evolution
Old 10-24-2012, 10:20 PM   #1
WhiteCobra94's Avatar
What's the difference between the solid air filters and the ones with the opening down the center ?
(Example pictures)
ID:	73468   Click image for larger version
Old 10-24-2012, 10:33 PM   #2
More filtering area & some use the center to better direct the airflow.
Old 10-25-2012, 06:53 AM   #3
Which one is better for n/a motors
Old 10-25-2012, 07:43 AM   #4
Imo as long as you have the most surface area you can get you are probably not gonna see much if any difference in performance.
Old 10-25-2012, 02:54 PM   #5
Well I have a 6in K&N air filter and when the car is running and I rev the throttle fast from the throttle body . Sometimes you here a pop coming from the (cai air filter) so I don't know maybe I put the wrong one on?
Old 10-25-2012, 06:59 PM   #6
Titus Wadicus
svtlx's Avatar
u may wanna check or "up" your fuel pressure a couple pounds. sounds like its running lean for that initial w.o.t. anyway, i believe what you hearing is detonation ... by lack of fuel, not a c.a.i. issue.
thats just my opinion though.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-25-2012, 07:32 PM   #7
Well I dont want to touch anything , I'll call the speed shop that dynoed the car and see .
I'll try and get a video of it, it only does it when the car first starts up it seems
Old 10-25-2012, 07:39 PM   #8
Titus Wadicus
svtlx's Avatar
well hopefully i dont know what im talking bout. but u should for sure call them and tell them its popping.
Old 10-26-2012, 06:15 AM   #9
IMO, the one that will filter/flow the most air (within reason) is always better to help ensure you have enough airflow.
I agree.
It's doing the same thing as a carb would if the pump shot was not big enough on initial acceleration.
Adjusting the fuel pressure up a few pounds won''t really "hurt" the tune and you could just back it off again if it caused adverse effects. No need in spending the money for the tuner if you don't have to, but of course the choice is yours.
Old 10-26-2012, 11:48 AM   #10
wc3john's Avatar
How do you turn up the fuel pressure on a stock fuel pressure regulator?
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-26-2012, 02:48 PM   #11
You can't.
01:28 AM
