rear end (clunk) on automatic - Mustang Evolution
Old 10-25-2012, 07:56 PM   #1
i have put new upper and lower controls arms, drag springs, adj shock and i just put a new ford racing drive shaft to fix this problem. the rear end clunks when i shifts. i have not open up the rear yet. the sound is mostly on the passenger side. oh ya the guy that owned the car but 3.73 gears in it so can you please help.
I'm worry about it because i have mickey drag radials.
Ponyexpressjr is offline   Reply With Quote
Old 10-26-2012, 08:15 AM   #2
Probably drive line slack.
Check the U-joints and the slip joint that slides in the transmission. If those are ok, then you may have a lot of slack in the ring and pinion gears.
Old 10-26-2012, 08:17 AM   #3
Titus Wadicus
svtlx's Avatar
r u sure your axel tube isnt hitting your "over axel exhaust pipe"? thats prolly y only hear it on the right side. its a common issue especialy if u have 2.5"-3.0" exhaust. i run dumps now..lol.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-26-2012, 10:17 AM   #4
I have changed the driveshaft with a new ford racing one. That helped a lil bit but there's still that clunk from the right side. When had the driveshaft off I was spinning flange on the rear end. There's was a lot of play in it but how do I check it to see where it should be.
---------- Post added at 12:17 PM ---------- Previous post was at 12:15 PM ----------
Nope my exhaust dump right before the rear end
Old 10-26-2012, 11:51 AM   #5
wc3john's Avatar
My money is on bad U-joints
---------- Post added at 12:51 PM ---------- Previous post was at 12:49 PM ----------
Does it do from a stop where you hold the brake, put it into gear and hear/feel the transmission go into the gear? If so, I'm almost 100% positive it's Ujoints... You should be able to get up under there and try and turn the driveshaft. If it moves at all, then it is the u joints.
Hope this helps
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-26-2012, 02:42 PM   #6
You will have to drain the rear end and pull the cover to check the backlash, better left to someone with experience/proper tools if you have none in that area. In and out axle play is normal because they are c-clip axles.
Old 10-28-2012, 06:06 PM   #7
Took the rear end cover off 2 nights ago and found all the spider gears were chipped and worn out so that's why it was clunk
05:11 AM
