hot!!!!!!!!!!!! - Mustang Evolution
Old 04-21-2008, 02:41 PM   #1
hot!!!!!!!!!!!!
I have an 89 mustang 5.0, and i am a new owner. The engine seems to run real hot, but my temp gauge does not work. I can't figure out the temp gauge, and is their something I need to look at to help cool my car.....thanks matt
matthewh is offline   Reply With Quote
Old 04-21-2008, 03:50 PM   #2
MonteCitan's Avatar
Re: hot!!!!!!!!!!!!
first off get a temperature gauge on it, 190-220 ish degrees seems hot, but is about right for most engines (220 is on the high side, though) as for the temp gauge, it's either the cluster, wiring or the sensor itself, but the gauge isn't terribly accurate, if it were me.. I would run an aftermarket temperature gauge (and one that uses its own sensor, not the stock signal..)
If it does indeed run hot, there could be several reasons why.. but with the age of the car most prominent would probably be sludge built up in the coolant passages... nothing a flush wouldn't fix... beyond that you could cool the car more with a better cooling fan, colder thermostat, etc
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-21-2008, 07:56 PM   #3
Send a message via AIM to rwboring
Re: hot!!!!!!!!!!!!
+1 to my knowledge fords run much colder then GMs... my 65 hardly goes above 170...
rwboring is offline   Reply With Quote
Old 04-23-2008, 01:39 PM   #4
Scut95's Avatar
Re: hot!!!!!!!!!!!!
My car also runs hot....i changed everything in the cooling system, flushed it and backed flushed it and it still runs hot....i ran an aftermarket gauge and the fan doesn't kick in until 250 degrees! Sorry i kind of high jacked this thread
Old 04-23-2008, 04:41 PM   #5
Re: hot!!!!!!!!!!!!
then you got some problems
Old 04-23-2008, 06:08 PM   #6
MonteCitan's Avatar
Re: hot!!!!!!!!!!!!
Don't get me started on problems
however, Scut, have you tried changing your fans.. to run at a lower temp?
Old 04-23-2008, 07:46 PM   #7
Scut95's Avatar
Re: hot!!!!!!!!!!!!
Not yet....im thinking about getting my car tuned and have them change the temp at which the fan kicks on....it is an electric fan that seems to suck a lot of air in, just not soon enough
Old 04-26-2008, 07:43 AM   #8
silverstangboy's Avatar
Re: hot!!!!!!!!!!!!
yours is an SN95 yes?
93 mustang notch
~450hp 331 stroker - Sold
Old 04-26-2008, 10:34 PM   #9
Scut95's Avatar
Re: hot!!!!!!!!!!!!
yes it is, 1995 GT 5.0......i even made sure i ordered the correct water pump when I replaced it, 94-95 is different from all the other 5.0's
Old 04-30-2008, 02:56 AM   #10
Re: hot!!!!!!!!!!!!
On my 95 I had the same problem. Got the fans to come on sooner and no more overheating.
I'm just loving curves!
willspank is offline   Reply With Quote
Old 06-04-2008, 02:13 PM   #11
Re: hot!!!!!!!!!!!!
my car was overheating so i changed the clucth fan it was sticking i replace it and now im around 220 good luck
87foxgt is offline   Reply With Quote
Old 06-05-2008, 09:38 AM   #12
Scut95's Avatar
Re: hot!!!!!!!!!!!!
some how my car runs normal now....i don't know how but o well...its always between 180 and 210 so that works for me
Hot 4 Hilary Brent Pictures and Videos 11 07-12-2007 12:44 AM
Will not start when hot SJLOGAN 1979-1995 Mustang GT 7 06-03-2007 09:02 AM
Now this is hot PureVenom Pictures and Videos 23 03-13-2007 07:43 AM
Its freakin hot outside Brent The Bar 57 03-09-2004 10:52 PM
08:56 AM
