94 - 3.8 to 5.0 Swap? - Mustang Evolution
Old 10-25-2012, 10:29 AM   #1
doing motor swap on 94 3.8 auto 4spd with push button OD, this car is DIS....car engine harness is a 42 pin out connector,cars trans harness is a 16 pin out connector. got a 98 explorer 5.0, which is also DIS, with engine i got engine harness,engine control computer, transmission harness....explorer 5.0 engine harness is a 42 pin out connector...explorers trans harness is 38 pin out connector...
would like to know if any one knows how i can make this car run as a DIS car.....can i splice the two harnesses together, or is there another way.
NOTE: car does not need to pass any emissions... so now that crap matters if it works or not.
Clutch302 is offline   Reply With Quote
Old 10-26-2012, 02:22 PM   #2
You're in uncharted territory for me.
I know you will need to use the 5.0 harness, but I don't really understand what you are asking if both engines are DIS?
You will have to get a Chiltons manual with good wiring diagrams and compare the two to see what the differences are.
Old 10-26-2012, 11:43 PM   #3
cuz i, going to make this 94 mustang into coil pack 5.0..... n i think im doing it ok, im merging the two harnesses together. from the 3.8 n explorer 5.0 harness.
Old 10-27-2012, 02:57 AM   #4
You want to be careful doing that or you are likely to fry some electronics or the ECU.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 12:12 PM
4 Cylinder to a 5.0 engine swap? Blackcat 1979-1995 Mustang GT 1 09-18-2012 05:26 PM
3.8 to 5.0 conversion. Need Tips! Justasix98 Pre-2005 V6 Mustang 10 12-21-2011 03:59 PM
5.0 swap into a 98 gt???? 98allblkgt 1996-2004 Mustang GT 6 11-23-2011 05:55 PM
02:12 PM
