No spark in the spark plugs - Mustang Evolution
Old 10-28-2012, 09:55 AM   #1
94GTpony's Avatar
I have no spark coming from my spark plugs. Put a spark plug tester on an nothing. Checked my coil pack even switched it out with a different one and nothing.checked the distributor it's turning but no spark any where. Any ideas?
94GTpony is offline   Reply With Quote
Old 10-28-2012, 11:32 AM   #2
Jar72's Avatar
Did u check the ignition fuses under the hood. Allways follow power issues backwards you've checked most of it plugs. Dist. Coil. Now on to ignition. Fuses etc. There are a lot of good diagrams online.
JMF
Jar72 is offline   Reply With Quote
Old 10-28-2012, 03:52 PM   #3
how did you test the coil? did you test resistance, or check for spark on the coil wire? also check voltage on the + wire of the coil.
Old 10-28-2012, 03:54 PM   #4
Bleem@1's Avatar
Not sure on 94 but most 5.0 had TFI module. They were normally the cause of no spark.
Bleem@1 is offline   Reply With Quote
Old 10-28-2012, 03:55 PM   #5
yes it should. there is a test procedure for the tfi in the useful info sticky thread.
Old 10-29-2012, 09:15 AM   #6
Battery is fully charged correct? Check cables?
You've checked for spark at the plugs, go backwards as suggested.
Check the cap & rotor.
Test the PIP
Test the TFI module
Test the coil
Not finding any problems in those areas may indicate an issue with the ECU.
Old 10-29-2012, 07:46 PM   #7
Billymich's Avatar
Just a thought, check engine grounds?
Old 10-30-2012, 01:20 PM   #8
94GTpony's Avatar
It wa a engine ground barely grounded down
06:39 AM
