Some transmission help - Mustang Evolution
Old 10-28-2012, 10:29 AM   #1
MC770's Avatar
Okay so I have a teemed tr-3650 in my fox and my reverse lights do not turn on in reverse, I crawled under the car to fix it since it has to be inspected soon and I believe this is the issue? If not what is this plug for?
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 10-28-2012, 10:30 AM   #2
MC770's Avatar
Some more pics and the last one is another plug nearby if anyone knows what that is I could always use the knowledge haha
ID:	73860   Click image for larger version
Old 10-28-2012, 10:55 AM   #3
aegischief's Avatar
That's is for the reverse lights.
aegischief is offline   Reply With Quote
Old 10-28-2012, 11:56 AM   #4
The last picture is your speedo cable.
JayKranz is offline   Reply With Quote
Old 10-28-2012, 12:37 PM   #5
MC770's Avatar
Alright thanks for the help, anyone know where I can get a new reverse light switch thing?
Old 10-28-2012, 12:39 PM   #6
aegischief's Avatar
From the pic looks like it just needs to be plugged back in. If not, then you can get one from a junk yard for cheap. You will need to cut and splice it in.
Old 10-28-2012, 12:41 PM   #7
MC770's Avatar
If you look closely one of the terminals is broken off and is the only place from a junkyard?
Old 10-28-2012, 12:41 PM   #8
Cjponyparts.com also carries some of that stuff if you don't find one in a junk yard they may have it.
Old 10-30-2012, 09:08 AM   #9
UPDATE:
We determined Matt has a Tremec 3550, not a 3650.
The switch he took pictures of is the neutral safety switch located near the end of the tail-shaft housing.
We may just leave it disconnected since it isn't harming anything with the broken wire.
His reverse light switch was actually located on the left side of the transmission housing, and upon removal and testing it was definitely bad.
I jumped the plug, and other than one bad taillight bulb, the wiring was fine and we replaced the bulb.
We ordered a new back-up light switch from CJ Pony Parts and it should be here/installed within the week.
Thanks for the help!
DD
DigDawg is offline   Reply With Quote
Old 10-30-2012, 09:11 AM   #10
Nice!
03:13 AM
