Temp Gauge "Floats" - Mustang Evolution
Old 10-28-2012, 04:43 PM   #1
Matt95GT's Avatar
Temp Gauge "Floats"
What would cause my temp gauge to float? One second its at normal temp then just drops a quarter if the way down then goes right back to normal.
Matt95GT is offline   Reply With Quote
Old 10-28-2012, 05:17 PM   #2
Either a bad sensor or air in the system.
Old 10-28-2012, 06:01 PM   #3
Matt95GT's Avatar
What sensor would it be if that is what it is?
If it is air how would I get that out?
Old 10-28-2012, 06:06 PM   #4
there should be a water sensor/sending unit on the intake somewhere in the water passage.
for air you can usually just runn it for a while with the cap off and it should burp out. then you may need to add coolant accordingly.
i would think he air is most likely the problem. whenever an air pocket gets by the sensor it is causing faulty readings.
Old 10-28-2012, 06:19 PM   #5
Matt95GT's Avatar
Thanks ill give that try and hope it solves the problem.
Old 10-28-2012, 06:20 PM   #6
hopefully ... if not let us know and we will see if we can figure out anything else.
Old 10-29-2012, 09:19 AM   #7
Yup, air bubbles or a possible broken sending unit wire are the most likely causes.
Old 10-29-2012, 07:41 PM   #8
Billymich's Avatar
Sounds like air, I had this issue 2 hours ago, with engine cold, open rad cap, and rev engine a few hundred RPMs higher than idle, hold it there till the temp gauge settle. Add coolant/water as needed Good luck
Old 10-29-2012, 08:21 PM   #9
Matt95GT's Avatar
Did this twice today and it is better now. Still floats a little but not nearly as much as it did.
Going to do it again tomorrow and see if that takes care of it. Hopefully it does.
Old 10-29-2012, 08:22 PM   #10
awsome man. make sure it gets to full rrunning temp for a while.
Old 10-29-2012, 11:42 PM   #11
Billymich's Avatar
Yeah these 5.0's have a lot of air pockets it seems...
Old 10-29-2012, 11:48 PM   #12
Kenny laird's Avatar
I jacked the front if my car up high as i could and it seemed to help getn all the air out
---------- Post added at 12:48 AM ---------- Previous post was at 12:48 AM ----------
Let it run like that for awhile with the cap off
Kenny laird is offline   Reply With Quote
Old 10-30-2012, 12:21 AM   #13
Matt95GT's Avatar
I'll try jacking it up and see if it helps get that little bit out.
I let it run for 30-45 minutes both times giving it gas every 5-10 minutes. Hopefully there is still a small bubble in there I can get out and not a sensor/sending unit problem.
03:04 AM
