Gt40 longblock - Mustang Evolution
Old 10-29-2012, 06:41 AM   #1
Kenny laird's Avatar
Gt40 longblock
Well finaly got motor in last night gt40 long block with e303cam and trick flow up top. Now time to start puting everything back together. Cant wait to drive it
ID:	73928   Click image for larger version
Kenny laird is offline   Reply With Quote
Old 10-29-2012, 06:42 AM   #2
wc3john's Avatar
I'll be interested to see what kind of power it makes... I have nearly a similar configuration with the exception of a gt40 tubular intake up top
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-29-2012, 07:11 AM   #3
Me to. U do have gt40 top end or stock 5.0 upper and lower
Old 10-29-2012, 07:11 AM   #4
wc3john's Avatar
Gt40 tubular top end
Old 10-29-2012, 07:17 AM   #5
I went wit the 75 mm trick flow upper and lower. Cant wait to see what it does
Old 10-29-2012, 09:43 AM   #6
If you don't have the matching heads and cam, then you won't notice much if any improvement.
Old 10-29-2012, 01:24 PM   #7
wc3john's Avatar
Even if its port matched?
Old 10-29-2012, 02:46 PM   #8
I dont have the matching heads. But my heads have been ported and polished the cam is e303 the motor was built by a mustang shop in sacramento it should def b better than the stock motor i had
---------- Post added at 03:44 PM ---------- Previous post was at 03:43 PM ----------
Eventualy would like to get the trick flow heads and cam but for now this will have to do. My budget is empty lol
---------- Post added at 03:46 PM ---------- Previous post was at 03:44 PM ----------
And yes my hheads and intake are port matched. I hope it runs strong. I will no tomorrow when i finish up
Old 10-29-2012, 03:43 PM   #9
The intake alone isn't going to make much difference without the heads that are matched to it. The GT40's flow a bit better than stock, but the Trick Flows, flow a lot better.
If he's going to the GT40 from his stock engine, then to him it will seem like a big improvement, but if you put one on your car that has been running the GT40 stuff already, I'm afraid you will be disappointed and you will probably lose some low end power.
Old 10-29-2012, 05:46 PM   #10
wc3john's Avatar
I have yet to see comparison numbers between trick flow and stock and or gt40's...
Old 10-29-2012, 06:23 PM   #11
Well, didn't the 93 Cobra(GT40) make 260HP or something like that? The trick flow top end kit is 350, what other numbers would be needed for comparison?
JayKranz is offline   Reply With Quote
Old 10-29-2012, 09:22 PM   #12
i *belive* the 93 cobra was rated at 240 or 245. but i have also heard that it is slightly underated. but yeah you pretty much said it in comparison.
Old 10-29-2012, 10:13 PM   #13
You are prob right im guesing it wont b much dif than a gr 40 intake but with 8 lbs of boost or so it should still b a fun ride lol
Old 10-30-2012, 06:10 AM   #14
Right, the boost will be different
Old 10-30-2012, 07:30 AM   #15
wc3john's Avatar
Yeah but the cobra didn't have an e303 cam
Old 10-30-2012, 08:06 AM   #16
wc3john's Avatar
I guess I wanna see flow numbers between the gt40 and the trick flow intake. I know the heads are better as well as the cam but I'm just talking about the intake only
---------- Post added at 09:06 AM ---------- Previous post was at 09:05 AM ----------
I know the primary hindrance to makin power on a stock motor is the heads. After that, you go with the intake next, then injectors and start working your way to the air filter
Old 10-30-2012, 12:08 PM   #17
I think we have flow charts for popular heads and intakes in the useful sticky thread.
Old 10-30-2012, 12:09 PM   #18
wc3john's Avatar
I'll check thanks!
gt40 p setup Robbie94gt 1979-1995 Mustang GT 5 02-03-2012 06:49 PM
Best year to get of gt40 intake tbonestang 1979-1995 Mustang GT 3 12-28-2011 10:08 PM
Gt40 heads VENOM 1979-1995 Mustang GT 15 11-23-2011 10:36 PM
Will GT40 Heads Handle A Big Cam?? 90Stang_5.0 1979-1995 Mustang GT 27 11-02-2011 03:12 AM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
10:59 PM
