cobra parts upgrades?? - Mustang Evolution
Old 10-31-2012, 09:50 PM   #1
Would the brake calipers from a 95 mustang cobra be a direct bolt on upgrade for a 95 gt??
fordracing63857 is offline   Reply With Quote
Old 10-31-2012, 11:44 PM   #2
Butch's Avatar
Region: New Mexico
I read it is a direct bolt on. Brackets for the caliper should fit with no problem, all you'll need is caliper and rotor, pads of course. Also saw you need 17" or bigger rims for the 13" suckers,
Some recommend a 94-98 Cobra master cylinder, but other say the GT MC is just fine.
Oh and break lines two
A simple cheap upgrade for better stopping? Not to shabby
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 11-01-2012, 07:46 AM   #3
jdavis96gt's Avatar
Region: West Virgina
You could upgrade to 99-04 MC. Its brake lines are 1" 1/16. The 94-98 are only 1". You only need to change piece where brake lines go. Since 1 1/16 wont go in 1" fitting.
Its supposed to take away the "spongy" feel.
Old 11-01-2012, 07:04 PM   #4
Are you talking about the master cylinder piston?
Brake lines are nowhere near 1", maybe you are talking about the brake line end fitting wrench size?
Old 11-01-2012, 07:43 PM   #5
jdavis96gt's Avatar
Don't give me hell, don't know how to post links from phone.
Its bore diameter. Google " 96-98 hydro boost master cylinder upgrade"
Don't know if it be worth it or not. My MC is starting to leak, that's how I found it.
Old 11-01-2012, 10:27 PM   #6
I was not "giving you hell" simply trying to clarify what you were talking about.
Too many times we get garbled posts from phone users that make little or no sense at all and we have to try and sort out what they mean. Asking you questions about what you posted was for that purpose.
Increasing the bore diameter would be a good thing in many cases as it will move more fluid with less travel. I have found numerous times over the years on different vehicles that the "factory" woefully undersized the MC bores and they were just adequate to do the job. Going to a larger bore master cylinder helped the pedal travel and feel considerably.
Old 11-02-2012, 04:17 AM   #7
jdavis96gt's Avatar
I meant giving me hell cause I can't post links lol. I know my pedal has always felt spongy. I didn't think it was the MC undersized. I just thought it was cause I needed rotors. (Car bounces bad when your hard on brakes.)
Old 11-02-2012, 06:45 PM   #8
Spongy pedal feel can be caused by several things, air in the system, old rubber lines that are damaged/weakened and expand when you hit the brakes, inferior brake pads and probably a few others I have forgotten. If your pedal pulsates and the car vibrates when you brake, then likely the rotors are warped and need to be turned or replaced.
Old 11-11-2012, 08:49 PM   #9
So reading this does the replacement of the master cylinder needed for 94-95???
EastTnStang423 is offline   Reply With Quote
Old 11-11-2012, 09:43 PM   #10
Butch's Avatar
Region: New Mexico
Id say personal choice and if needed once you run with the GT one
-----NEHP---
{Never Enough HP}
Old 11-12-2012, 11:49 PM   #11
Sybesma07's Avatar
I'm sure you won't but if you do replace the spindles and other stuff. I will take your old stuff? Just thought I would throw that out there ha. Wanna swap my 86 to 5 lug and better brakes.
Sybesma07 is offline   Reply With Quote
02:04 PM
