transmission slip after driven - Mustang Evolution
Old 04-24-2008, 06:15 PM   #1
Cool transmission slip after driven
need some advise after i drive my ,1994 5.0 automatic trans
begins to slip this started to happen after shift kit was installed .engine will
reve up to 3500prm trans will slip as if goinign into neutral let off gas pedal
rpms then reach 2500 to 2000 rpms and trans will engage have original trans
just a shift kit was installed ,what can i do??????
wax1 is offline   Reply With Quote
Old 04-24-2008, 11:49 PM   #2
Re: transmission slip after driven
I would recommend checking all the new parts installed in the car considering your problem just started after their install. Changing the trans fluid to a full synthetic fluid as well may help, unless the fluid on your dip stick is blackish and burnt in which case it may not be safe to flush. Also while checking, make sure the trans fluid isn't low, if so that will contribute to the slipping. Good luck, hope you get it fixed.
BLACKOUTMAN GT is offline   Reply With Quote
Old 04-25-2008, 07:04 AM   #3
it could be that the shift kit made the problem more noticable than it was before since it up's line pressure~ but it could be a problem with the install. Dont sit on it get it checked asap
Old 04-25-2008, 10:10 AM   #4
Herbstang's Avatar
a few things I can think of that would cause 'slip' would be worn clutches or faulty clutch activation mechanisms but usually it's a low or incorrect fluid problem
Old 04-25-2008, 08:06 PM   #5
rocknbronco's Avatar
X2 Also I would re check the valve body to make sure you dont have any trash in it.
rocknbronco is offline   Reply With Quote
Old 04-26-2008, 07:40 AM   #6
silverstangboy's Avatar
as spector said if your transmission was already on the weak side of its life span a shift kit will usually worsen things.
93 mustang notch
~450hp 331 stroker - Sold
Who has test driven a 2011 GT?? jimbullit 2011-2014 Mustang GT 78 12-09-2010 09:39 AM
Transmission Slip? Chaz385 Pre-2005 V6 Mustang 1 05-16-2008 07:48 AM
ss vs shoddy driven 04 cobra maximus Pictures and Videos 7 07-31-2007 07:35 AM
Fastest car youve ever driven? Tbird232ci The Bar 34 04-28-2004 01:54 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
06:41 PM
