Front sway bar - Mustang Evolution
Old 11-03-2012, 04:25 PM   #1
Ohdang1990's Avatar
Front sway bar
Will removing this at the track transfer weight better? I have a 1990 gt with pro comp shocks and struts, tubular upper and lower control arms and unknown springs. I don't transfer weight too well so any advice would help. Thank you
Ohdang1990 is offline   Reply With Quote
Old 11-03-2012, 07:20 PM   #2
it might not be noticable. but it should definitly help.
i would leave it on for street use though
Old 11-03-2012, 10:20 PM   #3
Yes, it will help a good bit by allowing the front end to raise higher and quicker.
I took mine off years ago and never really noticed much difference on the street, but then I don't do any corner carving either. They do help you keep better control of your car, so leaving it on for the street is probably the best option like dreamstang said.
P.S. A set of UMI Lift Bars in place of your lower control arms will help plant the rear tires even better.
05:51 PM
