tranny whine - Mustang Evolution
Old 11-03-2012, 09:13 PM   #1
Jar72's Avatar
tranny whine
As the title says my 5 speed is whining. I'm thinking fluid. Any other suggestions before I drain and replace. Also what's a good oil for trans and diff.
JMF
Jar72 is offline   Reply With Quote
Old 11-03-2012, 09:19 PM   #2
It could also be your throw out bearing, also known as clutch release bearing, when it starts to go it will start to whine or whistle. Does it change at all when you press the clutch down? Does it only do it at certain speeds?
keaton5.0 is offline   Reply With Quote
Old 11-03-2012, 09:39 PM   #3
lBRAlD's Avatar
A lot of tob posts in last couple of days. Mine has started squeaking for a few min after startup. I wonder if they are kinda of seasonal (go out at the first of summer and winter)
lBRAlD is offline   Reply With Quote
Old 11-03-2012, 10:32 PM   #4
Finchms's Avatar
The tob will cause noise but it sounds like u just need to check the fluid first. Its the cheapest and easiest.
Finchms is offline   Reply With Quote
Old 11-04-2012, 01:06 PM   #5
Jar72's Avatar
I'm lookin at royal purple synchmax. Good or bad.
JMF
Old 11-04-2012, 03:01 PM   #6
Finchms's Avatar
Im sure its good but never used it. I just use pennzoil synchromesh and it does good for me.
Old 11-04-2012, 03:13 PM   #7
Jar72's Avatar
Sounds good. Last question I've read it takes 2.5 to 3.2 quarts. Any hints on this ?
JMF
Old 11-04-2012, 03:14 PM   #8
Finchms's Avatar
Thats right. Bout 3 qts.
Old 11-04-2012, 03:15 PM   #9
Jar72's Avatar
Great thanks.
JMF
Old 11-04-2012, 03:16 PM   #10
Finchms's Avatar
Your welcome. Good luck!
05:12 PM
