3 symptoms - Mustang Evolution
Old 11-07-2012, 09:52 PM   #1
Jar72's Avatar
3 symptoms
Cold start it smells like fuel bad. After warm up it has a strong exhaust odor. Also car has a light idle surge. No issues with performance at all it screams and runs hard a hell. Timings at 14 no ping. Premium fuel. It does have cold air intake factory Maf performance throttle body. And the tps is at .98.
JMF
Jar72 is offline   Reply With Quote
Old 11-07-2012, 10:04 PM   #2
Sounds like an exhaust leak to me. Does the car have catalytic converters?
keaton5.0 is offline   Reply With Quote
Old 11-07-2012, 10:20 PM   #3
Jar72's Avatar
No cats bbk long tubes h pipe n flow master's the smell is from the tail pipes its harsh.
JMF
Old 11-07-2012, 10:29 PM   #4
Is your check engine light on? Maybe a faulty O2 sensor. I would check the spark plugs and see if their are any fuel deposits on them.
Old 11-08-2012, 06:42 AM   #5
Jar72's Avatar
O2 sensors replaced about 3 weeks ago. Th others were cut by previous idiot. I mean owner.
---------- Post added at 08:42 AM ---------- Previous post was at 08:39 AM ----------
Check engine comes on after warm up. I haven't ran the codes yet cause I was making sure I find and fix all the obvious issues. And there have been plenty of those.
JMF
Old 11-08-2012, 03:49 PM   #6
Check/replace your temperature sensors. IAT (Intake Air Temp) & ECT (Engine Coolant Temp).
Old 11-09-2012, 09:43 PM   #7
Adogg's Avatar
the same thing happens to me light comes on then off and smells like gas i think i need new headers were can i find a iat and ect car has proplem reading that i have coolant
Old 11-09-2012, 10:03 PM   #8
Any autoparts store should carry them, or could atleast have you them overnight
Old 11-09-2012, 10:10 PM   #9
Adogg's Avatar
how much r these parts and how hard r they to replace
Old 11-09-2012, 10:24 PM   #10
Roughly $20-$25 a piece. Pick up a chilton or haynes manual for your car also, it will walk you through pretty much anything on your car
Old 11-09-2012, 10:26 PM   #11
Adogg's Avatar
Will they have the manual at the parts store to?
Don't hate....... appreciate
Old 11-09-2012, 10:28 PM   #12
Yes they should. Smaller stores may not but any big name store will.
Old 11-09-2012, 10:30 PM   #13
Adogg's Avatar
Thanks guys sorry for stealing this thread
Old 11-14-2012, 03:57 PM   #14
Jar72's Avatar
Thumbs up
its all goodmines down for awhile, my rear control arm bushings are blown out. but i did fix some of these issues, i found the IAT was not sealed on and air was getting through the housing ( found this with carb cleaner while it was running) cleaned the IAT sealed it on made a bit of differnence now on to the ECT.
JMF
Old 11-14-2012, 04:49 PM   #15
If the sensors dont fix it ,,you could have a injector dripping a little when you shut it off,,
mymustang is offline   Reply With Quote
Old 11-18-2012, 05:05 PM   #16
Jar72's Avatar
Missed out by an hour. Oh well thanks for the info.
JMF
02:39 PM
