my 1987 mustang 5.0 lx idling problems - Mustang Evolution
Old 11-12-2012, 02:04 PM   #1
1987mustanglx50's Avatar
My 1987 mustang idles a bit funny when its in idle in stop or drive while holding the brake it goes up and down I say between 600 to 900 rpms if its left on for a bit it will turn off the more The car stays on the worst the idling get if I can get help thanks in advance really do appreciate it and I replaced the idle air control valve already and the throttle positioning sensor I cleaned the maf sensor and throttle body
1987mustanglx50 is offline   Reply With Quote
Old 11-12-2012, 02:22 PM   #2
Here's a picture of my engine in case this helps you guys
Old 11-12-2012, 04:30 PM   #3
Jeff44's Avatar
Did you check all your vacuum hoses and also if you did not change out your PCV valve, I would highly recommend replacing it.
Jeff44 is offline   Reply With Quote
Old 11-12-2012, 07:32 PM   #4
thank you i will check that
Old 11-13-2012, 07:26 AM   #5
Quball19's Avatar
Did you set the tps?.96 to .98
Quball19 is offline   Reply With Quote
Old 11-13-2012, 03:06 PM   #6
Kenny laird's Avatar
My car was doing same thing went through the steps of unhook and reseting idle and havent had a prob with it sense
Kenny laird is offline   Reply With Quote
Old 11-13-2012, 11:44 PM   #7
[QUOTE="Quball19"]
Did you set the tps?.96 to .98[/QUOTE ]
Am not sure but I will look were my tos is at and reset it if I have to thanks really do appreciate it
---------- Post added at 10:44 PM ---------- Previous post was at 10:43 PM ----------
I will try that thank you really do appreciate it
Old 11-16-2012, 09:01 PM   #8
jacob.a.gasparp's Avatar
Region: Nebraska
Ok this sounds exactly like what my 89 gt does it drives fine but after idling for awhile it dies, Idk if it is the fuel pump getting weak or what. So what is everyone's suggestion to solve this problem
jacob.a.gasparp is offline   Reply With Quote
Old 11-17-2012, 03:30 AM   #9
91notchback's Avatar
I would start by checking timing, fuel pressure, checking for vac leaks, etc. Basically all the simple and cheap stuff man.
91notchback is offline   Reply With Quote
Old 11-17-2012, 11:51 AM   #10
Yea I checked The timing it was way off it was at 17 degree btdc when it needed to be at 10 degrees btdc thank you everyone for your help
Old 11-17-2012, 12:04 PM   #11
Anytime man! I've learned the key is to always think simple when you start troubleshooting things :good
1987 mustang
11:45 PM
