Gonna get some spark plugs soon and wondering if I should get the autolite platinum or double platinum plugs or the Bosch platinum plugs for my 95 gt.....
For most performance usage I would use the plain old Autolite copper core plugs.
For long life street car use the platinum plugs are ok too, but do not use platinum plugs if using nitrous oxide.
I'm using the NGK iridiums which are 60k plugs on a 95gt and I've had no problems. They are pretty expensive tho. What's the benefits of using the oem type plugs? I've heard to stay with them from everyone it seems.
That's the main reason. Spark plugs are one of those things that you can spend as much or as little as you want. I personally like the fine tipped iridium plugs, but I won't use them until I really need them after installing my SC and tuning the engine. They are just to expensive otherwise and don't benefit the engine enough to warrant the extra cost.
According to an article I read some time ago it has something to do with the nitrous effect on the platinum spark plug coating and back then the ability to find the correct heat range in a platinum plug. They are also said to fire hotter and be less effective at transferring the spark than a copper core plug. Hotter is bad when running nitrous and you need all the ignition energy you can get to fire the mixture.
Nitrous Express also says this in their instructions:
Do not use platinum tipped spark plugs, the spark kernel is to small for
nitrous usage and cannot ignite the mixture at the cylinder pressures that nitrous creates.
Once you find the heat range you need using inexpensive plugs, switching to a fine tipped iridium plug may be beneficial. That's my plan for the SC installation and tuning. :good:
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
