Confused - Mustang Evolution
Old 11-14-2012, 02:03 PM   #1
Adogg's Avatar
Confused
Got new spark plug wires from am the blue ford racing one and can't get the smallest wire to fit on cause that gold thing is sticking out to far won't slide down I think they sent me the wrong ones
Don't hate....... appreciate
Old 11-14-2012, 02:13 PM   #2
93slowstang's Avatar
You have to slide the wire inside of it some more.
Old 11-14-2012, 02:15 PM   #3
Yup. That booty in the end will move if you give it some ***.
Old 11-14-2012, 02:16 PM   #4
Venomouz831's Avatar
Push it in!!
Lol jk
)02 Gt, Founder of WE2G
Old 11-14-2012, 02:24 PM   #5
It's not me, it's you.
primer2tone's Avatar
That connector may be bent in the wrong position. Slide the boot down the wire to get a better look at it.
Old 11-14-2012, 02:34 PM   #6
Adogg's Avatar
Not working I think they put the terminal in backwards the long end that is sticking out should be in the wire
Old 11-14-2012, 02:42 PM   #7
It's on right, just gotta break the boot loose from the wire.
Old 11-14-2012, 09:03 PM   #8
Originally Posted by Adogg View Post
Attachment 76025
That end looks like it is made for the old style coils?
Did they send any other coil wires?
Sometimes they include both types.
A bit of silicone spray lube will make the boots slide easy on the wires.
Old 11-16-2012, 04:51 AM   #9
Adogg's Avatar
That is the only one that size I called am and sent them a pic of it and never got back to me ill call them today again
Old 11-16-2012, 01:03 PM   #10
With that type of distributor cap, the coil wire on the distributor end should look just like the plug wires. You may have gotten a set for an older model or something? You can usually get the correct connector and boot at an auto parts store and just cut that off and replace it. Just be sure to follow the directions in prepping and crimping the connector in place.
Old 11-16-2012, 01:06 PM   #11
Tyoung68's Avatar
Is that wire going to a coil?
---------- Post added at 08:06 PM ---------- Previous post was at 08:05 PM ----------
Or is it going to a sparkplug
02:51 AM
