94 95 5.0 running bad quiting or won't crank cheep fix inside - Mustang Evolution
Old 05-01-2008, 09:57 PM   #1
eagle05's Avatar
Cool 94 95 5.0 running bad quiting or won't crank cheep fix inside
check and clean any metallic dust off the magnet inside the distributor with a half dozen Q-Tips. you need to take off the cap remove the rotor button remove the two screws holding the metal cup with the windows cut out of it. remove the metal cup thing, then just keep wiping clean Q-Tips over and around the magnet to remove metal dust from it. I pulled my distributor out but I'm sure you can clean it without pulling it.Hope this helps some one
:drive:95 GT T5 K&N filter B&M Pro ripper kicked the cats out and flowmasters :burnout:
eagle05 is offline   Reply With Quote
running bad help please scott3.8stang 1996-2004 Mustang GT 4 05-09-2009 11:14 PM
95 GT running bad wvstang5.0ho 1979-1995 Mustang GT 6 08-23-2008 10:50 AM
Owned a CRX pretty bad (pic of my date inside!) Autobadges.com Pre-2005 V6 Mustang 13 12-27-2003 12:17 AM
running from cops is bad....... mmmmkay? .:DarkEntity:. The Bar 10 10-11-2003 12:14 PM
08:03 AM
