cant figure car out - Mustang Evolution
Old 11-17-2012, 02:05 PM   #1
cant figure car out
Car is 89 lx with 5.0 explorer intake and p heads . start it up and it idles fine .give it some gas and it starts busting out @ maybe 2800 rpms . Sounds like it s on a twostepp...Can cycle the switch off and on 3 or 4 times and it goes away.... Sometimes I just let it idle a few minutes and drive on down the road and cut switch off and on and it is gone , by the way car is straight drive ,New plugs ,wires , cap and rotor and it still does it , HELP Also have tried a different computer
89lx5.slow is offline   Reply With Quote
Old 11-17-2012, 02:27 PM   #2
check:
timing- 10* btdc
fuel pressure- 38 with vacuum disconnected and plugged
also check for vacuum leaks and sure the egr is working
what switch are you "cycling" ?
p.s. you can bump the thread to help it get to the top of the thread list.. just please dont keep bumping it constantly. but creating repeat threads just clutters the boards. so i will go ahead and delete the other thread u made.
Old 11-17-2012, 03:03 PM   #3
the switch i am cycleing on an off is the ingition switch .......timing is @ 10 and no vaccum leaks.....just @ a loss been dealing with this since i bought car 5 months ago , It was sitting for maybe a yr or so and battery was dead. Thanks for your help in this matter also fuel pressure was fine
Old 11-17-2012, 03:10 PM   #4
Have you checked the injectors? I would get a noid light to be sure. And make sure the eye is functioning properly.
Old 11-17-2012, 03:10 PM   #5
Also forgot to mention coil. That could be a main suspect..
Old 11-17-2012, 04:55 PM   #6
fomoco4life's Avatar
:agree: and/or Points/Gap
Old 11-17-2012, 05:56 PM   #7
Havent checked injectors ,,have new msd coil ...........thanks fellows
Old 11-17-2012, 10:37 PM   #8
If not coil check the tfi module. A test procedure can be found in the stickies under useful information.
Old 11-17-2012, 11:52 PM   #9
Bleem@1's Avatar
Might also check the ignition switch. Make sure there is power on all the wires there should be.
Bleem@1 is offline   Reply With Quote
01:28 PM
