Mustang running way to rich. Any ideas - Mustang Evolution
Old 11-18-2012, 01:32 PM   #1
88 mustang. Can't figure it out
88orangestang is offline   Reply With Quote
Old 11-18-2012, 08:51 PM   #2
watson 1025's Avatar
How do u no its rich? Were the plugs fouled? Check fuel pressure? Ect?
watson 1025 is offline   Reply With Quote
Old 11-19-2012, 12:21 AM   #3
Billymich's Avatar
Are there any other symptoms, rough idle etc? Could be timing, could be a lot of things.
Old 11-19-2012, 05:22 AM   #4
Just smells like gas. Rough idol. Blowing rich smoke. Had some bare wires on injection harness so change it. Car is throwing a 95 code Gonna have to check all grounds and cleans sensors
Old 11-19-2012, 09:36 PM   #5
Has it been converted to MAF?
Code 95 - Fuel Pump Circuit Open-PCM To Motor Ground
Means that at some time you lost power to the pump, because of a bad connection or bad relay.
Old 11-20-2012, 05:14 AM   #6
Ok cause I had to replace relay to turn pump on. So then 95 code is just that then. I took cats off and noticed a little rich. But now it's way too rich. Thinking of swapping out EEC.
Old 11-20-2012, 10:24 AM   #7
Billymich's Avatar
Is your engine warming up fully? Mine was running really rich, and my fan clutch was bad so it was spining all the time plus my thermostat is bad so its stuck open, made my car run rich. Getting my stang back for the first time in a month and half since I bought it and its actually running right, now! super psyched
Old 11-21-2012, 04:44 PM   #8
I'll try that. Thanks. Will get back
09:06 AM
