BODY WORK - Mustang Evolution
Old 11-18-2012, 08:51 PM   #1
laroc88lxho's Avatar
BODY WORK
Today I remove the front headlight assembly on my fox body and on the driver side there is a little fiberglass damage which should not be a problem with my expertise in this field I am slightly stuffy the paint and applying filler primer I am also removing all moldings
laroc88lxho is offline   Reply With Quote
Old 11-18-2012, 11:45 PM   #2
I am going to go with a green primer and I am going to paint the moldings flat black and I am going to get the pony wheels when I am finished it will look pretty nice I am going with a Cobra R hood also
Old 11-19-2012, 04:55 AM   #3
Got any pics of the progress?
Old 11-19-2012, 07:49 PM   #4
I will have a few photographs of the work I'm doing tomorrow thank you
Old 11-26-2012, 12:32 AM   #5
Old 11-28-2012, 06:43 PM   #6
ID:	78304   Click image for larger version
Old 11-28-2012, 08:06 PM   #7
DerekJohnScott's Avatar
That's looking good.
DerekJohnScott is offline   Reply With Quote
Old 12-03-2012, 02:14 PM   #8
Thanks I cannot work today due to the rain that has been going on for the last past 3 days... What I'm doing is scuffing the original paint and applying rust Oleum edging primer after letting it dry for 2 days and scuff it then I will apply filler primer generously after that dries sand it with 220grit wet with a block 1 of those rubber squeegee you use for color sending would do just fine remember maintaining body line key. I will also be showing how 2 properly mask a car
06:50 PM
