1987 mustang 5.0 engine question - Mustang Evolution
Old 11-23-2012, 08:35 PM   #1
1987mustanglx50's Avatar
I have a 1987 mustang lx 5.0 engine that I was wondering if it will go with a wiring harness from a 1988 mustang lx 5.0 cause the engine on my 1988 mustang lx is going to need to be over hauled so I have this extra engine that I want to drop on my 1988 mustang lx 5.0 if anyone can help me I would much appreciate it cause so far the only thing I know that is diffrent is the connection to the maf sensor but I haven't look into it
1987mustanglx50 is offline   Reply With Quote
Old 11-23-2012, 08:38 PM   #2
deadsp0t's Avatar
Unless its been converted or a Cali car there should be no MAF.. Either way should be a direct swap, plug and play!
That's unimpressive
Old 11-23-2012, 08:39 PM   #3
Both cars are stock and both are California cars hopefully the engine is a direct fit that would be good thank you for your help
Old 11-23-2012, 08:56 PM   #4
DerekJohnScott's Avatar
I wouldn't think that they would change from 87 to 88, and since they are both Cali they should be identical.
DerekJohnScott is offline   Reply With Quote
Old 11-23-2012, 08:59 PM   #5
Yea that's true its only one year newer hopefully your right thank you for your help
Old 11-23-2012, 09:00 PM   #6
if they are both cali cars then they arent even close. thats what dead was saying. in 88 california cars went to MAF. the 87 was speed density.
but it would still be a good idea to go ahead and swap in the MAF stuff. which if the 88 is california, it would be perfect.
Old 11-23-2012, 09:05 PM   #7
They are both California cars and they both have a maf sensor its just the connection to the maf sensor is diffrent as far as I noticed that's the only thing so far that I have noticed diffrent but I haven't really looked into it hopefully the engine goes right in with no modifications done to the harness
Old 11-23-2012, 09:08 PM   #8
the only way thats possible is that the 87 has been converted to MAF. because it doesnt have that factory.
Old 11-23-2012, 09:22 PM   #9
I think the 1987 mustangs from california have maf sensors I have 2 87 mustang 5.0s and they have maf sensors and am the second owner to both and they both have maf as far as I know the owners told me that they are stock from everything and I know 2 friends that have them and they have maf sensors as well
Old 11-24-2012, 11:19 AM   #10
All 87s came factory speed density even the california cars. They would have had to be converted to mass air
keaton5.0 is offline   Reply With Quote
Old 11-24-2012, 11:36 AM   #11
+1 exactly.
Old 11-24-2012, 12:45 PM   #12
ok i will go monday to the ford dealer and ask and i also checked all data and shopkey5 and both say that an 1987 mustang lx 5.0 have a maf sensor
Old 11-24-2012, 12:48 PM   #13
deadsp0t's Avatar
Not to argue but I'm not so sure about that.. Never herd that before.. Maybe it was an option or they were built early in the 88' run as 87's?
That's unimpressive
Old 11-24-2012, 12:53 PM   #14
maybe
Old 11-24-2012, 01:32 PM   #15
maybe
I am 99.9999% sure no mustangs had MAF in 1987. The other .0001% is only for liability purposes.
Old 11-24-2012, 01:34 PM   #16
ok
Old 11-24-2012, 01:34 PM   #17
I will pick up the other .0001%. What is different between the two sensors on your cars? I know their is a 4 wire sensor and a 5 wire. Is that the difference you were referring to?
Old 11-24-2012, 01:40 PM   #18
no they both have 4 wires but the connection it self is diffrent one is round and the other is square
Old 11-24-2012, 01:41 PM   #19
deadsp0t's Avatar
Pics?
That's unimpressive
Old 11-24-2012, 01:41 PM   #20
Is the one on the 87 the square one?[COLOR="Silver"]
Old 11-24-2012, 01:53 PM   #21
No the 87 has a round connection the 88 has the square connection here's are some pics of both
ID:	77533   Click image for larger version
Old 11-24-2012, 02:41 PM   #22
Jeff44's Avatar
The 87 MAF is an add on. 87 was speed density only! Dream is correct!
Jeff44 is offline   Reply With Quote
Old 11-24-2012, 02:50 PM   #23
Never seen that square one before. Any numbers on it you can see?
Old 11-24-2012, 03:00 PM   #24
Yes afh55-02 3g30
Old 11-24-2012, 03:02 PM   #25
deadsp0t's Avatar
Bet the square one is an aftermarket conversion and the round one is a swap conversion.
That's unimpressive
Old 11-24-2012, 03:05 PM   #26
both sensors say ford on them
Old 11-24-2012, 03:06 PM   #27
deadsp0t's Avatar
Odd indeed.......
That's unimpressive
Old 11-24-2012, 03:10 PM   #28
Yea it is
Old 11-24-2012, 03:24 PM   #29
Definitely strange but if the square one is working properly i would just go ahead and use it
Old 11-24-2012, 03:25 PM   #30
Yea its working fine that's what am going to do thanks everyone for your help
Old 11-25-2012, 06:33 AM   #31
I don't think my 87 has either of them, but it isn't a cali car so it might not have come with it.
Old 11-25-2012, 11:48 AM   #32
Yea I think California cars are different from any other states cause California smog laws
Old 11-25-2012, 03:08 PM   #33
Correct. All 86-87 5.0s were speed density, in 88 only the California cars got the mass air system. All others remained speed density until 89 when ford equipped them all with mass air
Old 11-25-2012, 03:14 PM   #34
exactly! right on the nose.
Old 11-26-2012, 11:18 PM   #35
I asked the ford dealer today my cars came factory maf sensors from dealer and all 87 did come with a maf sensor California cars a different from any other states they need to run better/cleaner cause of smog laws here being more strict
1987 mustang
03:04 PM
