Rod and main bearing - Mustang Evolution
Old 11-24-2012, 11:46 AM   #1
04machazblue's Avatar
Okay so I am trying to figure out which rod bearings I need. Motor is already apart I have the number "CB634p STD" and the number on the main bearing can't really make out
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-24-2012, 01:30 PM   #2
What you really need to know is if they are standard size bearings or not
keaton5.0 is offline   Reply With Quote
Old 11-24-2012, 01:51 PM   #3
I believe there standard size I took both part numbers off the rings them self these are the rod bearings
ID:	77522   Click image for larger version
Old 11-24-2012, 01:59 PM   #4
It should say if they were oversize. When i took my motor apart the bearings had .020 stamped on them
Old 11-24-2012, 02:33 PM   #5
We're on the bearing
Old 11-24-2012, 02:51 PM   #6
I believe the "STD" on your bearings stands for standard.
Old 11-24-2012, 03:44 PM   #7
91notchback's Avatar
I believe the STD is for standard also. If you're crank has been turned in the past, it SHOULD have some kind of marking on how much under it was turned from the shop that did it.
91notchback is offline   Reply With Quote
Old 11-24-2012, 03:48 PM   #8
I thought so too thanks guys and rings are 1.5mm 1.5mm 4.0mm I just got the car a month Go I took piston number 4 out today and the top ring was in two
Pieces
Old 11-24-2012, 07:10 PM   #9
You prolly already know this, but I'd recommend getting the crank turned if you're gonna have it out. 10 under should be fine if there are no deep gouges. It's like $100 or so at my local shop, and sure beats goin through bearings. Good luck man!!
04:08 PM
