331 with stock heads and intake - Mustang Evolution
Old 11-24-2012, 09:53 PM   #1
Im in the middle of rebuilding a motor for my fox and im going to pick up a 331 stroker kit from dss racing. Unfortunately a HCI upgrade will likely be out of the question until next winter when i put it away again but id like to drive it this spring/summer. Obviously it would make peak horsepower fairly low in the rpm range but how do you guys think it would do just as a driver for the time being?
keaton5.0 is offline   Reply With Quote
Old 11-24-2012, 10:02 PM   #2
93slowstang's Avatar
It would be fine as a daily until you got the hci swap. I would hate to have to tear it apart again when it's already at that point now.
Old 11-24-2012, 10:11 PM   #3
Well i could do the hci with it in the car. And since i live in ohio and i put it away in the winter due to snow and ice it would give me something to do next year if i do pull it back out.
Old 11-25-2012, 12:32 PM   #4
Do it man. You'll be fine.
JayKranz is offline   Reply With Quote
Old 11-25-2012, 03:05 PM   #5
Did you have to notch your block jay?
Old 11-25-2012, 03:34 PM   #6
It was done for me. You definitely need to.
Old 11-25-2012, 03:41 PM   #7
Ok. It has to go to the machine shop anyway to be bored. Cant wait to have all the parts, starting on pulling the old motor out tonight!
Old 11-25-2012, 04:05 PM   #8
Do you have a budget for this? Also, are you building the engine yourself?
Old 11-25-2012, 05:18 PM   #9
You could get some GT40's for a few hundred bucks.
Old 11-25-2012, 06:27 PM   #10
Havent really set a budget, just kinda playing it by ear which is why itl have the stock top end for a bit, and yes il be doing tbe assembly myself. Looking to send 375 or so to the wheels. Nothing crazy just a respectable driver
Old 11-26-2012, 07:56 PM   #11
04machazblue's Avatar
You should do a h/ci instead of the stroker you won't see much gain with 331 on stock heads and intake, do the heads and intake on the 302 u will be happy the do the 331
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-26-2012, 08:01 PM   #12
Good point
Old 11-26-2012, 08:08 PM   #13
Yeah. Im kind of thinking about just doing a 306 for now. I have a few other things in mind for the car id like to spend some money on before i get too heavy into the motor. Maybe just a low compression 306 and boost it later? That should hit the same amount of power im looking for as the 331 would.
Old 11-26-2012, 08:09 PM   #14
Just about
Old 11-27-2012, 05:51 AM   #15
I know a lot of guys that run decent heads cam and and intake with a s-trim make great power on a 302 enough to put them in high "tens"on a very street able setup. No need to do a 306 with a blower. Rebuild the motor bearings and piston rings I just ordered myn off summit cost me 150$
07:38 PM
