Overheating - Mustang Evolution
Old 11-26-2012, 04:27 PM   #1
silvrbullet2012's Avatar
Overheating
Im posting here since the other thread area seems pretty dead. So I changed to a new radiator,new thermostat everything seems to be fine but it wants to overheat? Water pump is good also. Could there be something I'm missing? Oh and it's a N/A 2.3 with 106k.
silvrbullet2012 is offline   Reply With Quote
Old 11-26-2012, 04:46 PM   #2
91notchback's Avatar
Hairline crack in head? Slight head gasket spray? Any leaks man? Sounds like you've been all around it though...lol! Just throwing out ideas....
91notchback is offline   Reply With Quote
Old 11-26-2012, 05:08 PM   #3
Billymich's Avatar
It may be running lean, how does it run?? Is the idle normal? Any hesitation when you mash the gas?
Change the oil check it for coolant.
Old 11-26-2012, 05:10 PM   #4
+5.0!
Old 11-26-2012, 05:16 PM   #5
aegischief's Avatar
Did you put the thermostat in correctly? A buddy of mine put one in backwards once.
aegischief is offline   Reply With Quote
Old 11-26-2012, 11:54 PM   #6
Ha. You know I'm sure I did. But might as well double check the thermostat!!
You know it is a little hesitant when I mash the gas. Ill give that a look at too!
Thanks everyone for they're help!
Old 11-27-2012, 03:29 PM   #7
Billymich's Avatar
Yeah, you may want to get a timing light and check the timing.
Old 11-27-2012, 03:33 PM   #8
Ha. It actually was a lil off. Now it's set right and runs ways better! Never would have thought of it!
11:30 AM
