need help - Mustang Evolution
Old 11-28-2012, 09:41 AM   #1
need help
my 94 gt is running very rich, it is bone stock with 150,000 miles. i have checked the codes and i get an egr low flow and an o-2 lean left bank. maf is clean, idle air control is bad it think due to irratic rough idle, i also have a constant check engine light and air bag and anti lock light even after all codes are cleared. any thought?
fcapel4 is offline   Reply With Quote
Old 11-28-2012, 09:56 AM   #2
McNassty's Avatar
How are you checking codes?
McNassty is offline   Reply With Quote
Old 11-28-2012, 02:13 PM   #3
Billymich's Avatar
Check timing, check spark plug (are they fouled). Whats the engine temp at (is it the stock gauge?) give us more info please
Wait, your getting a left bank O2 lean or the left bank is running lean? Do you have a vacuum leak? Does it sound like it?
Old 11-28-2012, 03:47 PM   #4
need help
i have replaced all vacuum lines , checked for intake gskt leaks, cleaned maf and iacv new plugs wires and dist cap. cleaned and oiled k&n fliter recently, but after problem started. i dont want to start throwing parts at this car unless i have direction. im old school shadetree mechanic and this is my first personal car that is injected. yes i have just graduated to this milennium. the car will fly at wot but blows black smelly smoke when i step on it. any ideas? also i used the inexpensive actron code extractor
---------- Post added at 05:42 PM ---------- Previous post was at 05:40 PM ----------
also engine temp is normal on stock gauge. everything on this car is stock i believe
---------- Post added at 05:47 PM ---------- Previous post was at 05:42 PM ----------
and i replace fuel pump, and filter, checked pressure regulator and have 32psi at idle
Old 11-28-2012, 05:12 PM   #5
Billymich's Avatar
Exhaust leak?
Old 11-28-2012, 10:40 PM   #6
McNassty's Avatar
Supposed to be 38.5 at idle, and what are you hooking up to to get codes? '96 and up are when they started using ports for the code readers
Old 11-29-2012, 06:52 PM   #7
yes it has exhaust leak on pass bank, extracting codes with actron hand held. have put 3 airtex fuel pumps for low pressure issues, below 20 barely runs, but now i have major fuel system issue.way too rich. im gonna throw a pressure regulator on and see what happens
10:50 AM
