mustang turning off after spark plug change - Mustang Evolution
Old 11-29-2012, 12:17 PM   #1
nsguido415's Avatar
Yesterday i changed out my spark plugs followed the wire so i wouldn't mix anything up on the cap. Car turns on idles perfectly. When i go to put the car in first gear i give it some gas and car turns off. Turn the car back on idles with no problems. I dont put it in gear but rev the engine car doesnt rev up. Struggles to rev up and turns off right away.
nsguido415 is offline   Reply With Quote
Old 11-29-2012, 12:32 PM   #2
McNassty's Avatar
Sounds like you may have mixed up the wires, that's why you should only Chang one spark plug at a time. Do not take off the wires pull the plugs change the plugs and than put the wires back on. If you didn't do this I apologize but it sounds like you did and mixed up the plug wires
McNassty is offline   Reply With Quote
Old 11-29-2012, 12:43 PM   #3
nsguido415's Avatar
I did change one at at a time. I even checked the wire diagram and everything correct
Old 11-29-2012, 12:47 PM   #4
McNassty's Avatar
Than if have to say pull your plugs and check them, the plugs you got may not be gapped to the correct gap
Old 11-29-2012, 12:50 PM   #5
nsguido415's Avatar
I figured that might be they said gap was .54
Old 11-29-2012, 12:54 PM   #6
McNassty's Avatar
Lol, 0.052 is the correct gap
Old 11-29-2012, 01:03 PM   #7
91notchback's Avatar
I assume he meant .054, since theres no way in hell he could run a gap that's .04 over a half inch...lol. I agree though. If your car breaks up off of idle, it sounds to me like you are either a plug off of firing order, or one isn't connected good and misfiring.
91notchback is offline   Reply With Quote
Old 11-29-2012, 01:04 PM   #8
McNassty's Avatar
Lol, I figured
Old 11-29-2012, 02:14 PM   #9
nsguido415's Avatar
Ok so i unplugged the battery checked em to make sure they were good. Waited 20 mins plugged the battery in drove it down the street got to the stop and the car did it again. Gave it gas had no power and turned off
Old 11-29-2012, 02:34 PM   #10
:weird: And you didn't pull any wires off your dizzy cap? The reason I ask is: It's easy to put your number one wire where the number three wire goes. Did you change wires when you did plugs?
Old 11-30-2012, 12:14 AM   #11
Billymich's Avatar
Even if one of the plugs was off, it wouldn't do it. My 5.0 ran with Pistons 1 and 2 not firing (disconnected) and the timing like WAY off, I drove it four blocks no problem.
Old 11-30-2012, 02:19 AM   #12
Mine ran with a wire off firing order, but ran like a turd. This is just weird to me with nothing but a plug change gapped at .054 man....
Old 11-30-2012, 02:37 AM   #13
Jeff44's Avatar
Sounds like a fuel problem!
Jeff44 is offline   Reply With Quote
Old 11-30-2012, 08:59 AM   #14
McNassty's Avatar
But it didn't start until he changed his spark plugs
Old 11-30-2012, 09:58 AM   #15
nsguido415's Avatar
It use to start up just fine before. Upgraded cam changed injectors fuel pump fuel regulator mass air flow. My car was running just fine. Then the car started backfiring and would shake when you gave it gas. Now i changed the spark plugs and car just doesnt run
Old 11-30-2012, 12:10 PM   #16
Billymich's Avatar
Ahhh, so there's the missing information! I knew something wasn't right!
Old 11-30-2012, 12:12 PM   #17
nsguido415's Avatar
What could it be
Old 11-30-2012, 12:20 PM   #18
nsguido415's Avatar
So pretty much my car ran perfectly fine i bought the car a cam, fuel injectors, fuel reg, mass airflow, new intake manifold, throttle body, cold air intake. Car drove perfectly fine no problems. Then the car started struggling when you gave it gas almost like it didnt want to run while it back fired and had no power. While in neutral no problem idle was great. Gave it gas no problem. Put the car in first gear started driving car would start back firing and shaking. Got to the stop sign car rpms would go up and down then after 10 seconds car would turn off. I would go to turn the car on the car wouldn't turn on. If i hit the gas then turned the key the car would turn on. No idle problems. Drive little bit and the problem would start all over. Unless i was at the light in neutral giving the car a little gas. Was too scared to drive the car so i would just take it home. I changed the throttle position sensor, indle control and the baf sensor. Now that i changed the spark plugs and cables. The car is not drivable. Put it in first gear i could slam on the gas and the car just turns off
Old 11-30-2012, 12:59 PM   #19
McNassty's Avatar
What size cam did you change to?
Old 11-30-2012, 02:44 PM   #20
you may have gotten a bad plug imo. i have seen this a few times. when you pulled them back out to check the gap, did you notice if any of them were wet? i would check spark at every cylinder to insure the ALL plugs and wires are good.
Old 11-30-2012, 03:35 PM   #21
Billymich's Avatar
Pshaw! I mean if you want to take the easy way out. I say just replace EVERYTHING!
Old 08-25-2015, 04:05 PM   #22
Jbone007's Avatar
Hmm, back fire and no power = timing issues!
Jbone007 is offline   Reply With Quote
Old 08-25-2015, 04:40 PM   #23
Strange Mud's Avatar
I would like a feature that asks "are you sure you want to resurrect a thread from 3 years ago?"
Old 08-25-2015, 04:45 PM   #24
Jbone007's Avatar
Yes I guess I should look at the date lol
Old 08-25-2015, 06:58 PM   #25
This is what happens when you do all those mods and no tune. You need a tune. And you need to list EXACTLY the parts you got as in what cam, what MAF, what injectors etc... etc...
Did you even change the pushrods when you did the cam? As in measure for the correct new length and then order them and install the right ones?
07:03 AM
