Front tire rub? - Mustang Evolution
Old 12-01-2012, 02:32 PM   #1
DerekJohnScott's Avatar
Front tire rub?
So I went to get new tires because mine are 8 years old and dry rotted and they said that they wouldn't put new tires on and they said they wouldn't because the tires on it are rubbing, what could be causing this? Too big of tires? It is happening on both sides.
ID:	78730   Click image for larger version
DerekJohnScott is offline   Reply With Quote
Old 12-01-2012, 02:46 PM   #2
They said it could be a bent a-arm too, but why would it be both sides.
---------- Post added at 03:46 PM ---------- Previous post was at 03:41 PM ----------
My 100th post! Classified here I come!!! Woo hoo?
Old 12-01-2012, 03:12 PM   #3
225/60/r15 is what's on it, stock they are 225/55/vr16. Could it be that they are 5 to wide? Am even right with this? They are in millimeters to right? 225mm/55mm?
Old 12-01-2012, 03:27 PM   #4
TrickFlow94's Avatar
Wrong offset
TrickFlow94 is offline   Reply With Quote
Old 12-01-2012, 03:34 PM   #5
Originally Posted by TrickFlow94
Wrong offset
How do I fez that?
---------- Post added at 04:34 PM ---------- Previous post was at 04:33 PM ----------
Originally Posted by DerekJohnScott
How do I fez that?
Fix*
Old 12-01-2012, 04:26 PM   #6
Get stock sizes tires back on it. It should tell you the size in the driver or passenger door. If that's not it possible a arm problem.
Jadams
jadams is offline   Reply With Quote
Old 12-01-2012, 04:53 PM   #7
Compstall's Avatar
How fo you get a 15" tire on a 16" rim
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 12-01-2012, 05:01 PM   #8
The first number is the width, second is the sidewall height
Old 12-01-2012, 05:01 PM   #9
They should make that size for a 16rim
Old 12-01-2012, 07:25 PM   #10
Burkeys96GT's Avatar
That is true but the second number Is a percent of width as height so sidewall is 60percent of 225 mm
Burkeys96GT is offline   Reply With Quote
Old 12-01-2012, 07:52 PM   #11
Kinda...that's the general idea. All manufacturers vary on what the sizes actually measure however.
Old 12-01-2012, 08:45 PM   #12
Sybesma07's Avatar
Your size tire is just fine. There's something else that's causing it to rub. You should have plenty of room with those tires. You can even put 16 and 17" wheels with wider tires then you have now.
Sybesma07 is offline   Reply With Quote
Old 12-01-2012, 11:05 PM   #13
Could it be that they are simply turning too far? They only rub when I turn as far is I can.
Old 12-02-2012, 01:28 AM   #14
93slowstang's Avatar
Your tire size is fine. The factory rack limit clips may not be there. Especially if the rack has been changed.
Old 12-02-2012, 03:48 AM   #15
wc3john's Avatar
Let me get this straight....
You have stock wheels correct? ( turbines )
It hasn't pulled left or right on the highway?
And it's rubbing or wearing on the inside or the tire?
What vibrates, the car or the steering wheel
And 225 is mm wide 55 is the RATIO to the sidewall to the width of the tire.
Finally, do you hear it rubbing when you turn the wheel lock to lock and drive slowly in a circle?
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 12-02-2012, 09:29 AM   #16
Stock rims, doesn't pull, doesn't shake except for the flat spots on the tires they only rub when I turn as far as possible. There isn't really any wear on the tire, just the grease is rubbed of the a arm where they touch.
Old 12-02-2012, 09:35 AM   #17
wc3john's Avatar
Well from that I can tell you the things it isn't...
Which sometimes is and isn't much help
Only rubbing lock to lock usually means wheels/tires too big but you have stock which means since the are stock it can't be offset.
Since it doesn't wear/pull/shake the alignment is NOT out ( or at least not out enough to be of concern )
No vibration means that the balance is correct.
The only thing you can do really is change the wheels and tires and see if the problem persists.
If it does, then it has to with something else on the suspension or something in the steering as previously mentioned is bad. ( Out of my area of expertise )
I hope this contributes!
Old 12-02-2012, 01:12 PM   #18
That's what it is. I've got the part ordered. Thanks for the help!
---------- Post added at 02:12 PM ---------- Previous post was at 02:08 PM ----------
Thanks for the help! Luckily it isn't the the wheels so I don't have to get new rims. Phew.
Old 12-02-2012, 01:31 PM   #19
Glad you got it sorted out.
Old 12-02-2012, 01:34 PM   #20
wc3john's Avatar
You mind taking pictures where the problem was?
Old 12-02-2012, 01:36 PM   #21
He did, it's in the first post.
Old 12-02-2012, 01:41 PM   #22
Here
Old 12-02-2012, 03:02 PM   #23
wc3john's Avatar
I was talking about the steering rack clips or what not? Or am I looking at them in the picture? Reason is is that I have no idea what they look like or where they go
Old 12-02-2012, 03:10 PM   #24
Here's a link in case you need help installing, or part #s. http://vb.foureyedpride.com/showthread.php?t=115969
01:06 AM
