87 mustang 5.0 - Mustang Evolution
Old 12-03-2012, 08:08 AM   #1
Jmanlev's Avatar
87 mustang 5.0
Mustang makes a noticeable noise when turning off the engine.??
Jmanlev is offline   Reply With Quote
Old 12-03-2012, 08:19 AM   #2
What kind of noise?
Old 12-03-2012, 08:29 AM   #3
Jmanlev's Avatar
It sound like a turning noise comes to a stop when a turn off the car. I know that's normal but it's kinda louder than normal and I can somewhat feel it in the drivers seat.
Old 12-03-2012, 08:33 AM   #4
Hmm... Mine makes a noise when I shut it off also. But it would be hard for us to really pin point what it is. If its bothering you, could you make a video of it?
The only other thing I can suggest is having someone shut the car off while you investigate where the noise is coming from. If you are having trouble hearing it out side the car, I like to use a mechanics stethoscope. They work great for tracking noises.
Old 12-03-2012, 08:37 AM   #5
Jmanlev's Avatar
Ok I totally appreciate it man. When and if I can i will make a video of it.
Thanks
Old 12-03-2012, 08:52 AM   #6
Thanks
No problem..
Old 01-20-2013, 09:52 AM   #7
I have a 87 gt also and I'm have a hell of a time getting power from my relay under the seat to my fuel pump.I'm getting power to the relay and yes I just replaced the relay, but it stops there no power from there to the fuel pump.I even crossed the wires over and bypassed they relay and can't get any power to the impact switch in the trunk. any ideas???
headrush229 is offline   Reply With Quote
Old 01-20-2013, 10:12 AM   #8
Check the inertia switch.
P.s. if its more than this go ahead and start your own thread so we can better easily assist you.
Old 01-20-2013, 04:24 PM   #9
Jeff44's Avatar
It sounds like your fuel pump relay that's under the driver seat. I had the same problem. Pull it out and plug it back in. Eventually you will need a new relay.
Jeff44 is offline   Reply With Quote
Old 01-20-2013, 04:46 PM   #10
Ignition problems I think
---------- Post added at 06:46 PM ---------- Previous post was at 06:44 PM ----------
[/COLOR]And I have a new relay and fuel pump but now its not wanting to crank and the ignition is sticking when its does decide to crank
10:42 PM
