Spark plugs and spark plug wires??? - Mustang Evolution
Old 12-04-2012, 05:40 PM   #1
Moyhuerta's Avatar
What spark plugs nd spark plug wires will work good on a MSD distributer i was thinking going wit 9mm wires but i dont know nd my motor is stock???
Moyhuerta is offline   Reply With Quote
Old 12-04-2012, 05:55 PM   #2
havhammer's Avatar
Ford racing wires and autolite platinum plugs is what I run.
havhammer is offline   Reply With Quote
Old 12-04-2012, 05:58 PM   #3
Moyhuerta's Avatar
But will 9mm wires will be good
Old 12-04-2012, 06:01 PM   #4
deadsp0t's Avatar
Yup. There is really no need for platinum plugs. Plain auto lite copper cores work great.
That's unimpressive
Old 12-04-2012, 06:11 PM   #5
havhammer's Avatar
Ford racing wires are 9mm and im using them with a msd pro billet dist. But I forgot when I did my heads I switched to ngk coppers cuz for the head design I needed a "wider spark front"
Old 12-04-2012, 06:12 PM   #6
Moyhuerta's Avatar
I have a question my car didnt pass smog check they told me it needs a tune up but will the spark plugs nd spark plug wires will it help
Old 12-04-2012, 06:55 PM   #7
Billymich's Avatar
Maybe, did they say anything else? Is your engine warming up fully? Check your timing. Any check engine lights?
Old 12-04-2012, 06:59 PM   #8
Moyhuerta's Avatar
Well it does warm up normaly but on the 25mph run i guess it loses power
Old 12-04-2012, 11:49 PM   #9
Billymich's Avatar
You might not be getting full ignition if you're losing power. Check the power output at the alternator and Battery. Then maybe check spark plugs and move on from there.
Old 12-04-2012, 11:53 PM   #10
Moyhuerta's Avatar
Yea might be dat cuz my car dosnt turn on in the first time it turns on in the second try
Old 12-05-2012, 08:17 AM   #11
Billymich's Avatar
What does it sound like when you try to start it up?
Old 12-05-2012, 08:42 AM   #12
Moyhuerta's Avatar
It sound normal when i turn it on it just strugles to start
10:25 AM
