Diagnostics Question - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Old 12-05-2012, 02:18 PM   #1
94GT302's Avatar
94GT302 is unknown around these parts
Went to oriellys used there scanner. It pulled a code that just said cylinder 8 which my guess is a misfire and then something about the SPOUT being grounded can anyone explain that thank you
94GT302 is offline   Reply With Quote
Old 12-05-2012, 02:54 PM   #2
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
From what I've been reading it seems to be a worn pip sensor in the distributor.
Old 12-10-2012, 05:53 AM   #3
94GT302's Avatar
Would the pip cause it to run erratically and died when it gets warm???
Old 12-10-2012, 10:17 AM   #4
Moderator
It can. The tfi module can as well. Here's the procedure to test them so you're not just throwing parts at it. http://351winsor.com/joel/Ignition_Systems/tfi2.html
Old 12-13-2012, 09:58 AM   #5
94GT302's Avatar
I have replaced the TFI and it still does it. Could the IAC be a factor?
Old 12-13-2012, 11:17 AM   #6
Moderator
The iac shouldn't be a factor. If its not the tfi module it's likely the PIP in your distributor.
Old 12-13-2012, 12:38 PM   #7
91notchback's Avatar
91notchback is unknown around these parts
From my understanding, the IAC has more control when the car is cold.
91notchback is offline   Reply With Quote
Old 12-14-2012, 10:44 AM   #8
94GT302's Avatar
I've changed the PIP before but unfortunately it could be bad again -_- really thinking about buying a new MSD distributor
Old 12-14-2012, 11:22 AM   #9
94GT302's Avatar
Would the TPS be a factor because of the surging idle it has? And also when it's surging the volt gauge is erratic as well
Old 12-14-2012, 04:49 PM   #10
Billymich is unknown around these parts
Surging Idle could be vacuum leak (usually is) could be dirty MAF, bad ignition timing. Could be a lot of things... Really good sticky on it at the top! Lmk if you need help tracking all this down... I recently had to deal with the same thing
Old 12-14-2012, 05:13 PM   #11
Senior Member
dreamstang is unknown around these parts
you can also have a short in your charging system since your volt gauge is erratic. this can domino effect into your ignition system.
Old 12-14-2012, 05:26 PM   #12
True true, but if his Idle is dropping really low due to surging his alternator might not be outputting enough... just a thought, good call though
Old 12-14-2012, 06:37 PM   #13
Senior Member
yup thats also a possibility.
Old 12-14-2012, 06:39 PM   #14
Senior Member
i would do the ignition systems tests previously mentioned. and to answer a earlier qustions. if you bought a cheap/china/autozone tyoe pip then yes it could go bad quickly. but as stated i would test it, not just replace it.
« HP help? | E5 Heads »
02:51 AM
