Valve Train noise - Mustang Evolution
Old 12-05-2012, 11:43 PM   #1
Billymich's Avatar
Valve Train noise
So ever since I rebuilt my heads and did all the gaskets, I've had a sound of metal nocking around. It seems like the sound level is based on the amount of throttle Im giving it. I thought it was a number of other things but I ruled them out. When I was putting the rocker arms back on, I only torqued them to spec, I didnt check any clearances nor remove pushrod lash... Im really not sure what the correct process is for adjusting the rocker arm nuts. I was told I could remove the valve covers and see that way, but it seems like a decent amount of work and I have cork gaskets and would need to replace them. Any Ideas on where to start... I really dont need a pushrod bending or worse. I was getting some gas in my oil ( Gas in my oil ) its all in this thread. Now I'm wondering if I had an exhaust or intake valve not opening is it possible that would cause the gas in the oil too? Just some thoughts, thanks in advance!
Old 12-06-2012, 02:12 AM   #2
93_347foxbody's Avatar
Maybe the rocker arms hitting the valve cover
93_347foxbody is offline   Reply With Quote
Old 12-06-2012, 10:58 AM   #3
Billymich's Avatar
Even if it was torqued to spec? How bad would that be? Should it be first on my list to check and will I need a replacement gasket?
Old 12-06-2012, 07:08 PM   #4
Billymich's Avatar
Seems like the noise is getting progressively worse. Im pretty worries about it at this point. I don't know what my first step should be...
Old 12-07-2012, 05:59 AM   #5
Pull the valve covers and take a look. Get rid of the cork gaskets while your at it
JayKranz is offline   Reply With Quote
Old 12-07-2012, 10:26 AM   #6
Billymich's Avatar
What kind of gaskets should I get? Where from? Whats the correct procedure for adjusting the rocker arms.
Old 12-07-2012, 01:10 PM   #7
I got the ones that are rubber with a metal film in the middle. I think FelPro made them.
Old 12-08-2012, 06:52 AM   #8
TrickFlow94's Avatar
Sounds like your valve train is misadjusted. Valve could be staying open or closed.
Does it have a real bad idle?
TrickFlow94 is offline   Reply With Quote
Old 12-08-2012, 07:10 AM   #9
havhammer's Avatar
Did you put different rockers in like 1.7? What kind of valve covers and heads? Your rocker could be hitting a baffle on the inside. First thing would be to pull the valve cover and look for signs of them hitting. Make sure you look on the underside of the cover also.
havhammer is offline   Reply With Quote
Old 12-08-2012, 03:15 PM   #10
Billymich's Avatar
No, idle is alright, I believe I figured it out today at the garage! So I believe it was a loose header on the driver side. Torqued them to 24ft/lbs and it is almost all gone.
Old 12-08-2012, 03:25 PM   #11
91notchback's Avatar
I always use copper gaskets and lock washers. I hate exhaust leaks!! They are easily mistaken for tapping lifters, etc...
91notchback is offline   Reply With Quote
Old 12-08-2012, 03:29 PM   #12
I use RTV copper and no gasket.
Old 12-08-2012, 03:31 PM   #13
Billymich's Avatar
And that works alright? I have what looks like an alum gasket that spans all of them... seems pretty standar.
Old 12-08-2012, 03:36 PM   #14
The gasket is standard. My car is turbocharged and I don't have any leaks
Old 12-08-2012, 03:38 PM   #15
Is that just like a silicone type Jay?
Old 12-08-2012, 03:46 PM   #16
Billymich's Avatar
Permatex ULTRA COPPER RTV SILICONE GASKET MAKER from Nicholson’s
like this?
Old 12-08-2012, 05:45 PM   #17
Haha, that is exactly the one I use. You don't have to use it though. You can use gaskets, that's just how I do it.
Old 12-08-2012, 06:20 PM   #18
+1!...lol!
Old 12-08-2012, 07:42 PM   #19
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I have seen a buddy of mine do that and swear by it but I always run the felpro 9001's from advance(think that's what they are, been a while since I've actually needed to get any)
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
03:59 AM
