HELP - repair cost? - Mustang Evolution
Old 12-12-2012, 03:21 PM   #1
Jmanlev's Avatar
HELP - repair cost?
Mechanic said my clutch as compressor is going bad..is that a expensive repair? He couldn't tell me right off the bat.
Jmanlev is offline   Reply With Quote
Old 12-12-2012, 05:39 PM   #2
Is there a typo in this "clutch as compressor"? Not sure what you mean.
JayKranz is offline   Reply With Quote
Old 12-12-2012, 05:39 PM   #3
Jmanlev's Avatar
Clutch and compressor
Old 12-12-2012, 05:41 PM   #4
Fan clutch? A/C compressor? or drivetrain?
Old 12-12-2012, 05:41 PM   #5
Jmanlev's Avatar
Fan clutch and a/c compressor
Old 12-12-2012, 05:43 PM   #6
Ah, fan clutch you can change yourself for less than $100 and maybe thirty minutes of work. The ac compressor is between $150-200 depending on where you by it. You can install it yourself but you may be better having a shop do it for you.
Old 12-12-2012, 05:45 PM   #7
Jmanlev's Avatar
Yes fan clutch and a/c compressor
---------- Post added at 06:44 PM ---------- Previous post was at 06:43 PM ----------
Ok cool thanks man. I may just have both done by shops
---------- Post added at 06:45 PM ---------- Previous post was at 06:44 PM ----------
Ok thanks I appreciate it
Old 12-12-2012, 05:45 PM   #8
It's $250-300 in parts plus labor. Maybe $500 total or so.
---------- Post added at 06:45 PM ---------- Previous post was at 06:45 PM ----------
No problem
Old 12-12-2012, 05:53 PM   #9
Jmanlev's Avatar
Ok and would that cause my car to make a weird noise when I start it and shut the engine down
Old 12-12-2012, 05:54 PM   #10
It certainly could. Either one of those things alone would make noise potentially.
Old 12-12-2012, 05:56 PM   #11
Jmanlev's Avatar
Ok we'll I just found out that its a compressor with the clutch inside of it so replacing the a/c compressor would fix my problem. Another question. Not getting this fixed immediately, what other problems could this cause?
---------- Post added at 06:56 PM ---------- Previous post was at 06:56 PM ----------
Because I don't even use my air conditioner in the car
Old 12-12-2012, 06:02 PM   #12
Ah okay, it'll just be noisy but if you don't use your ac just buy a delete pulley for $50 and remove it.
Old 12-12-2012, 06:07 PM   #13
Jmanlev's Avatar
Ok is it hard to remove a compressor and add a delete pulley
Old 12-12-2012, 06:08 PM   #14
Nope
Old 12-12-2012, 06:09 PM   #15
Jmanlev's Avatar
Ok thanks man
Old 12-12-2012, 06:30 PM   #16
Jmanlev's Avatar
I also hear the sound when I turn on my car and shut it down and I never have the air on is that normal?
Old 12-12-2012, 06:33 PM   #17
The pulley is always spinning if the car is running.
Old 12-12-2012, 06:40 PM   #18
Jmanlev's Avatar
Ok makes sense. Can you pls tell me what I need to take off and put back on. I'm going to do it myself tomorrow.
---------- Post added at 07:40 PM ---------- Previous post was at 07:38 PM ----------
With the delete pulley that is...
Old 12-12-2012, 06:46 PM   #19
Yes because the pulley is spinning.
---------- Post added at 07:46 PM ---------- Previous post was at 07:44 PM ----------
Here is one video. Google it a ton of stuff comes up. I will help you if you get stuck tomorrow. You'll see it's not that hard.
Old 12-12-2012, 06:47 PM   #20
Jmanlev's Avatar
Ok thanks alot man I'm just beginner at this stuff but willing to learn.
Old 12-12-2012, 06:49 PM   #21
You will see its not too tuff.
Old 12-12-2012, 06:54 PM   #22
It's not me, it's you.
primer2tone's Avatar
Old 12-12-2012, 07:17 PM   #23
Jmanlev's Avatar
Should this be empty? It's connected to my a/c compressor.
Old 12-12-2012, 07:17 PM   #24
Jmanlev's Avatar
I checked where that black top is and it completely empty
Old 12-12-2012, 07:31 PM   #25
That is your power steering pump and no empty is bad. That is probably where you noise is coming from.
Old 12-12-2012, 07:33 PM   #26
Jmanlev's Avatar
Ok will add power steering to that.
---------- Post added at 08:33 PM ---------- Previous post was at 08:33 PM ----------
Is their a relay switch I can bypass the a/c compressor since I don't use
Old 12-12-2012, 07:49 PM   #27
You don't really need to bypass the ac. Just leave it alone if it's not making noise.
Old 12-13-2012, 05:27 PM   #28
Billymich's Avatar
If it is empty its probably leaking, clean it up, add more fluid, see where its leaking. Also that would be making a noise.
What "should" it cost to re-ring and assemble my engine? JayKranz 1979-1995 Mustang GT 27 10-21-2012 08:29 PM
Deer Repair BAD LUCK Just_John Pre-2005 V6 Mustang 8 01-11-2012 11:26 PM
Front bumper and hood repair Taywi General Mustang Discussion 7 09-12-2011 01:00 PM
cost kalell420 1996-2004 Mustang GT 7 09-09-2011 10:25 PM
True dual cost. GoldenPonyBoy 2011-2014 V6 Mustang 9 07-18-2011 11:26 AM
06:46 PM
