headlights kill battery. - Mustang Evolution
Old 12-16-2012, 09:19 AM   #1
Jar72's Avatar
Here it is. Thought my headlight switch was bad. I would have to wiggle it to get dash lights and headlights at the same time. Replaced it and same issue. This time is shorted the battery any suggestions? i am pulling the whole dash today. I will fin d and kill the gremlin in my car. For those who have seen my posts before i thinking of changing the cars name to frankenstang due to all mismatched bs the previous owners did.
JMF
Jar72 is offline   Reply With Quote
Old 12-16-2012, 11:21 AM   #2
Jar72's Avatar
Yet again. Found a mess of wiring in the dash that makes no sense. Cuts splices mixed up wires. Time to solder and replace.
JMF
Old 12-16-2012, 12:14 PM   #3
Jar72's Avatar
What is this? Its not in the wiring diagram and i have a factory cluster. Car had a viper system but I pulled it (wired wrong go figure)
JMF
Old 12-17-2012, 09:16 AM   #4
DerekJohnScott's Avatar
Well I hope that you like fixing stuff and it isn't your dd. But hey that's the best way to learn your car, I know I like doing it! Good luck.
DerekJohnScott is offline   Reply With Quote
Old 12-17-2012, 03:33 PM   #5
Jar72's Avatar
Lol. Yup. Its part of an overlay and its wired wrong. Go figure.
JMF
Old 12-19-2012, 05:07 PM   #6
LAS97GT's Avatar
Jar72, read your prof man. Retirement car? I did the same. I'm Army infantry (22+). Good luck with the rewiring job. Go fast when your done.
---Las97GT
Old 12-19-2012, 05:20 PM   #7
Jar72's Avatar
Thanks las97gt. I think its all done cant find any shorts at all. And everything works again.
JMF
Old 12-19-2012, 07:12 PM   #8
if you wiggled the switch and it temporarily fixed the issue, its most likely the wiring coming off of it. your gonna have to use wiring cpshemarics and chase the problem. of course starting at the switch. make sure each wire that is suppose to gets voltage when it is suppose to. then check all the wires with voltage with continuity to ground with power off.
02:31 PM
