Injectors and pump? - Mustang Evolution
Old 12-17-2012, 12:31 PM   #1
Chefnick's Avatar
Injectors and pump?
I will be I staking a novi 1000 supercharger. What size injectors and pump should I get. I also may be putting heads on it soon as well. Would 24# get the job done?
Chefnick is offline   Reply With Quote
Old 12-17-2012, 12:50 PM   #2
It all depends what horsepower level you would be at. Any guesses? Depends on heads too, if you get Gt40 that will make much less power than an AFR head.
JayKranz is offline   Reply With Quote
Old 12-17-2012, 03:30 PM   #3
Chefnick's Avatar
Prob not gt40
---------- Post added at 04:30 PM ---------- Previous post was at 04:29 PM ----------
No clue on horsepower. It's stock with a mold cam and exhaust.
Old 12-17-2012, 03:35 PM   #4
If you use the stock heads and intake and stay under 250-275 rwhp the 24lb injectors would be fine. If you add aluminum heads, intake and turn up the boost so your in the range of say 300-400 rwhp, I'd jump to 42 lb injectors. That's just me though and I do t like to strain my injectors.
Old 12-17-2012, 04:57 PM   #5
Billymich's Avatar
You should never run your injectors at more than 80% duty cycle
Old 12-17-2012, 05:39 PM   #6
+1
Old 12-17-2012, 05:46 PM   #7
Billymich's Avatar
RC Fuel Injection
Found this in the stickies, hope it helps!
Old 12-17-2012, 06:29 PM   #8
Chefnick's Avatar
Thanks
04:36 AM
