Yet another problem. - Mustang Evolution
Old 12-17-2012, 10:02 PM   #1
DerekJohnScott's Avatar
So today I decided to tackle another project, getting light on the inside. Well I went down to the good old advanced auto and first tried to get a new bulb for the map light, which I learnt is obsolete, but I don't think it works anyways. So I got a new bulb for the dome light and it lit up, but it didn't go off. I have takin it out, but I do want to fix it
---------- Post added at 11:02 PM ---------- Previous post was at 11:00 PM ----------
What could it be? The switches in the doors? Something else?
DerekJohnScott is offline   Reply With Quote
Old 12-17-2012, 11:56 PM   #2
Billymich's Avatar
Do you have a multimeter? Start testing!
Old 12-19-2012, 05:01 PM   #3
LAS97GT's Avatar
For an 87, your wires are slowly getting old. Like the previous post said get a m- meter and do some tests. Try searching for power further down the wire in case the ends are worn. They turn brown instead of copper. Means less conductivity. A Meter with a buzzer helps to find ground easier. Work your way back to the fuze box. Any wire you skin make sure u tape it up. My 2 cents. I have a 97, so I can imagine.
---Las97GT
Old 12-19-2012, 08:36 PM   #4
That makes since, but the light doesn't go off, would that be caused by old wiring? I would think if it was old wiring the light wouldn't come on.
Old 12-21-2012, 11:20 PM   #5
Update. I got the dome light working properly! All i did was soak the push button things in the door jams down with some liquid wrench penetrating oil and let it sit for a few days. Put the bulb in and shut the door and it went off!
Old 12-21-2012, 11:24 PM   #6
2300turboford's Avatar
Is ur insurerment gauge dimmer switched on?
Old 12-22-2012, 11:22 AM   #7
No, it was the switch in the door.
05:01 PM
