88 gt - Mustang Evolution
Old 12-22-2012, 06:22 AM   #1
Bford024's Avatar
88 gt
Clutch won't disengage, doesn't matter if the clutch pedal is pushed in or not. Transmission won't shift in any gear when car is running.
Bford024 is offline   Reply With Quote
Old 12-22-2012, 08:36 AM   #2
If the cable isnt broken, it sounds like the throw out bearing to me. Did it make a whining noise from the transmission area before it went out?
keaton5.0 is offline   Reply With Quote
Old 12-22-2012, 12:31 PM   #3
Billymich's Avatar
My 88 is starting to whine when the clutch is depressed.... Oh and from dead stops when the clutch and flywheel full engage it clicks kinda. Sound like my clutch is going bad?
Old 12-22-2012, 03:29 PM   #4
Bford024's Avatar
It makes a grinding noise when I try to put it in gear but won't go. The clutch pedal does make a noise when I push it. I just changed the clutch and bearings out about 5,6 months ago
Old 12-22-2012, 03:35 PM   #5
deadsp0t's Avatar
Sounds like your syncro's are done to me..
That's unimpressive
Old 12-22-2012, 05:00 PM   #6
93slowstang's Avatar
+1, or maybe you need to adjust the cable.
Old 12-22-2012, 05:01 PM   #7
deadsp0t's Avatar
Thought that as well.. Maybe it's(cable) stretched out too..
That's unimpressive
Old 12-22-2012, 11:23 PM   #8
Bford024's Avatar
I adjusted the cable, but it's still doing tha same thing. Thinking a spring in the pawl or quadrant maybe?
Old 12-23-2012, 03:28 PM   #9
foxbox's Avatar
I had the same problem after my clutch flew apart
foxbox is offline   Reply With Quote
Old 12-26-2012, 05:49 AM   #10
Bford024's Avatar
What did U do to fix it?
Old 12-26-2012, 06:19 AM   #11
Sampey43's Avatar
If yall are tired of turning wrenches on the old fox, and are ready to pull the trigger on a new stang, then shoot me a pm. Im in the market for a fox, especially a coupe!!! Thanks!!!
Sampey43 is offline   Reply With Quote
Old 12-26-2012, 09:31 AM   #12
foxbox's Avatar
I had to replace the clutch, I also put in a new cable and quad at the same time. In the end, pieces of the clutch got wedged between the pressure plate and clutch, which caused the clutch to not disengage.
07:25 PM
