What heads should i be running???? - Mustang Evolution
Old 12-22-2012, 10:23 AM   #1
Dustin541's Avatar
Region: Oregon
Buying some heads when I get my taxes this year don't know what to get
I have a brand new 308 short block I am building up using my x303 cam gt40 intake manifold and 24lb injectors stuck between choosing the head somebody help eventually I want 500 to the wheels and not much more
And my car has 4.10s and a t5
Dustin541 is offline   Reply With Quote
Old 12-22-2012, 10:49 AM   #2
AFR 185's. They are expensive though. AFR claims they make 95hp over the GT40x heads.
JayKranz is offline   Reply With Quote
Old 12-22-2012, 11:05 AM   #3
Dustin541's Avatar
Region: Oregon
Are they going to be better than track heat 185s or 170s
Old 12-22-2012, 11:09 AM   #4
2300turboford's Avatar
My dad is using afr 185r heads and they made a HUGE difference
---------- Post added at 01:09 PM ---------- Previous post was at 01:08 PM ----------
Afr is the best head u can get for a sbf
Old 12-22-2012, 11:12 AM   #5
I have a set on my dining room table that'll be installed this Spring. I "think" from my research that they would be great for your build.
Old 12-22-2012, 11:14 AM   #6
Dustin541's Avatar
Region: Oregon
I am trying to get more bang for my buck I am trying to find some flow numbers between afr and trick flows 185s
Old 12-22-2012, 11:17 AM   #7
My friend had some trick flows and switched to afr 165 and he said it was a completely different car
Old 12-22-2012, 11:24 AM   #8
Dustin541's Avatar
Region: Oregon
These are what I am gonna choose between
http://m.summitracing.com/parts/afr-1420
http://m.summitracing.com/parts/tfs-51416410-c01
Old 12-22-2012, 11:31 AM   #9
Trust me u will not regret getting the afrs
Old 12-22-2012, 11:33 AM   #10
Dustin541's Avatar
Region: Oregon
Is the gt40 intake decent enough or is it gonna hold me back a lot?
Old 12-22-2012, 12:01 PM   #11
Ewokjax95's Avatar
I'm curious about the Gt40 intake holding back these heads as well. The only manifold for sale on AFRs website is the edelbrock rpm 2 so I assume its the best flowing. A little expensive tho.
Ewokjax95 is offline   Reply With Quote
Old 12-22-2012, 12:03 PM   #12
I have the RPM II, based on the same I go you found.
Old 12-22-2012, 12:13 PM   #13
WhiteCobra94's Avatar
Your not gonna get 500 rwhp unless you do a stroker and and power adder.
I'm running a 308 with HCI , 30lb injectors and I'm at 310rwhp
My brother has a 347 stroker motor with AFR 225 heads and the Holley System Max II intake and he's dynoed in at 445rwhp
Old 12-22-2012, 12:14 PM   #14
Agrees
Old 12-22-2012, 12:23 PM   #15
Ewokjax95's Avatar
Why not just throw a T trim vortech on your already h/c/i setup? I don't think the V-3 would push enough boost for 500hp but the V-1 should.
Old 12-22-2012, 12:28 PM   #16
But will the V-1 add 200 + rwhp ? That's alot of boost on a stock block
---------- Post added at 01:28 PM ---------- Previous post was at 01:25 PM ----------
The safest way would be stroker with 6-8 psi on a safe tune!
Old 12-22-2012, 12:31 PM   #17
Ewokjax95's Avatar
I've seen 550hp at the crank on a somewhat stock block LS1 from a V-1. I guess you'd really need a beefed up 302 setup tho. It wouldn't seem very streetable at all tho.
Old 12-22-2012, 12:36 PM   #18
Yea the v-1 is rated to 20psi and that stock 302 most likely would split right down .
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
Are your internals forged in your 308 shortblock ?
Old 12-22-2012, 11:17 PM   #19
DSS Racing sells a main girdle that they claim enables a stock 302 block to handle 650+, but you will still need a good tune
keaton5.0 is offline   Reply With Quote
Old 12-24-2012, 03:49 PM   #20
Dustin541's Avatar
Region: Oregon
I don't want all 500 right now just always to buy stuff to support it till I throw a turbo on it
I been reading on the afr 185s alot and it doesn't sound like they work on a stock block so that's not good for me right now since I don't have the money to buy new pistons with valve releifs
Old 12-24-2012, 03:54 PM   #21
Where did you find that they don't work on a stock block? Just curious to read that.
Old 12-24-2012, 03:56 PM   #22
They work on a stock block , but you'll have to get your pistons cut for valve clearance !
Old 12-24-2012, 03:58 PM   #23
Any idea what the difference is with valve clearance? The pistons on my block were notched for the Holley Systemax kit heads and I thought I'd bolt these AFR's right on but there may be a difference.
01:50 PM
