94 cobra vibration issue - Mustang Evolution
Old 05-20-2008, 06:54 PM   #1
i just baught a 94 cobra last year that had a moderate vibration at about 2,ooo rpm and up. the guy that I baught it from had put a new harmonic balancer on it last year because the old one was bad. i recently put new motor mounts in it, changed clutch and preasure plate, had the flywheel turned. the vibration still has not went away. if anything it seems to have gotten worse. would he have gotten a bad harmonic balancer, or should I have replaced the flywheel rather than having it turned. or could it be internal? any help would be greatly appreciated.
fredericcobra is offline   Reply With Quote
Old 05-21-2008, 07:37 AM   #2
Re: 94 cobra vibration issue
define the vibration, entire car, clutch, rear end? etc
Old 05-21-2008, 04:04 PM   #3
it vibrates the entire car. seems to be comming from the front. the motor looks like it doesn't vibrate at all from the outside but when you sit in it you can definetly feel the vibration.
Old 05-21-2008, 07:49 PM   #4
You sure you don't have a flat spotted tire or a well worn tire?
Old 05-22-2008, 07:43 AM   #5
it vibrates at a stand still but it does seem to get a little worse when driving down the road.
Old 05-24-2008, 03:07 PM   #6
Scut95's Avatar
drive shaft out of balance? was the engine rotating assembly ever messed with? If the internals were replaced and not balanced the whole car would vibrate bad.
Old 05-25-2008, 03:24 PM   #7
silverstangboy's Avatar
if the engine hasn't been messed with internally, i'd do a engine balance test and see if you can locate a problem down to a single cylinder.. alot of things that could actually be.
93 mustang notch
~450hp 331 stroker - Sold
Old 05-28-2008, 03:28 PM   #8
thanks for all the replys guys. I just baught a new flywheel and replaced the original one that I had turned and it cured the vibration. Evidently the flywheel must have been warped or out of balance or someone could have put the wrong one in before I bought it? I am not sure what the heck happened, but its fixed with the new flywheel. woohoo!!
Old 05-28-2008, 03:52 PM   #9
Scut95's Avatar
nice....glad to hear you got the problem fixed....its usually really difficult to find vibrations and noises.
Old 05-29-2008, 07:23 AM   #10
glad you found such an odd problem, ive never heard of that unless somebody installed a flywheel from a different year.
SimplyOrange is offline   Reply With Quote
Old 05-30-2008, 06:55 PM   #11
I wonder if someone installed the wrong counterweight on the old one? Glad you got it working though!
93 mustang notch
vibration spw1001 1979-1995 Mustang GT 7 10-04-2008 01:21 PM
bad vibration dodgeman340 1979-1995 Mustang GT 8 03-19-2008 08:22 AM
Weird Vibration Jeremym831 1996-2004 Mustang GT 2 01-08-2008 07:32 AM
1995 Cobra "Fuel or Exhaust Issue" one95cobra 1979-1995 Mustang GT 9 11-05-2006 12:20 AM
Sound Vibration megax29 Mustang Audio & Video 14 04-04-2006 09:21 PM
02:07 AM
