2.3 to 5.0 build - Mustang Evolution
Old 12-27-2012, 10:11 AM   #1
93_FoxBody's Avatar
2.3 to 5.0 build
I started this build a couple months ago. I found a wrecked 92 gt for a donor car. Took the motor rear end wiring Ecu and all the usable parts. As to the motor all it had done was a e303 cam and ported gt40 upper and lower. I bought a Anderson n51hr cam, gt40 heads that have been ported double springs 1.6 rr value job an 10 degree angle locks, bbk intake spacer.
Here's the car before the start.
93_FoxBody is offline   Reply With Quote
Old 12-27-2012, 10:16 AM   #2
93_FoxBody's Avatar
ID:	82877   Click image for larger version
Old 12-27-2012, 11:48 AM   #3
cgarray17's Avatar
Looks like quite the project, I'm doing a blower and motor swap myself in the spring. Good luck and keep us up on the progress!!!
94 GT Convertible
Current- Stock long block 118k, MAC CAI, 75mm Pro M MAF, PP 70mm TB,BBK shorties,BBK O/R H, Magnaflow catback, KING cobra clutch, 3.73 Gears
Soon to be Vortech blown with a built 306 Numbers and times to follow!!!
cgarray17 is offline   Reply With Quote
Old 12-27-2012, 11:52 AM   #4
93_FoxBody's Avatar
I will. After its done looking to do nitrous probably a 150 or 175. Thought about a 200 shot know a few people that's done that
Old 12-27-2012, 11:59 AM   #5
cgarray17's Avatar
Did you do anything to the internals? If they are stock i would be very careful with anything over 125 shot. Someone with more nitrous info will chime in i know more about boost lol
94 GT Convertible
Old 12-27-2012, 12:02 PM   #6
93_FoxBody's Avatar
It's all new stock internals. I personally seen a stock bottom end 302 spray 200 shot many passes then he blew it with a huge ahot
Old 12-27-2012, 12:12 PM   #7
cgarray17's Avatar
I guess it all depends on what you ate going to use it for. Mine will be a dd with about 450 rwhp on 12-14 psi but I'm going for a safe longevity tune lol until i build a new boss block motor but that won't happen for a long time.
94 GT Convertible
Old 12-27-2012, 12:15 PM   #8
If your using hypereutectic pistons which came stock in 93 id take it easy on boost/nitrous. You will have people tell you hypereutectic pistons are good, which they are, but if i was running spray or boost id go forged.
keaton5.0 is offline   Reply With Quote
Old 12-27-2012, 01:40 PM   #9
93_FoxBody's Avatar
The motor came out of a 92 gt. I got the same pistons that I took out. And I'm only using the car for weekend/drag car. I probably won't do. 200 like my buddy did but atleast 150
04:46 PM
