Finally New heads - Mustang Evolution
Old 12-28-2012, 11:07 AM   #1
04machazblue's Avatar
Finally New heads
I finally got some new heads trick flow track heat 170cc got a anderson n41 for cheep edelbrock intake just need a carb finally the motor is coming together hoping to make atleast 300hp to the wheels
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 12-28-2012, 07:42 PM   #2
Awesome man. Those are the same heads im running. They completely changed the car! I went with a 670 aluminum street avenger carb. I am having lots of lean problems though. Its runs great but my a/f is off a bit. I have rejetted a few times already and still need to go bigger. Makes me wonder if I needed a bigger carb. I am using the wieand stealth intake with my setup.
Old 12-28-2012, 07:46 PM   #3
2300turboford's Avatar
Deamon carburetors are really good
Old 12-28-2012, 07:49 PM   #4
They are really good. But holleys are way easier to tune imo.
Old 12-28-2012, 07:59 PM   #5
1lowGT's Avatar
Amen to that
Old 12-28-2012, 08:04 PM   #6
Their just sensitive try making smaller Changes
Old 12-28-2012, 08:53 PM   #7
WhiteCobra94's Avatar
You should be close , with my setup I dynoed at 310 rwhp with the edlebrock top end kit and bored motor
Old 12-28-2012, 10:18 PM   #8
From what I hear a lot guys are dynoing from 295-330 tops but loads of trq, I don't usually dyno my cars I go by track times just want to hit high 11's with my set up going 430's btw
Old 01-05-2013, 03:25 PM   #9
I know they all
Look the same but I wanted to share my joy so pertty
Old 01-05-2013, 04:15 PM   #10
I know they all
Niiiiiiiiiice!!!!
Old 01-18-2013, 09:01 AM   #11
Update for my build just got trick flow 1.6 rockers for my old e7 heads and a 100 bucks came with rods that measure 6.700 were used on trickflow heads, all
I need is a msd box and hook my fuel up and then this bad boy be started
Old 01-18-2013, 06:04 PM   #12
Sweet good luck!!! Take a vid!
Old 01-20-2013, 09:47 AM   #13
Varasios's Avatar
Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L TFS-K514-360350B
http://www.summitracing.com/parts/tf...rd?prefilter=1
I was thinking of saving for this package, good bang for the buck?
Varasios is offline   Reply With Quote
Old 01-20-2013, 10:09 AM   #14
Yes
JayKranz is offline   Reply With Quote
Old 01-20-2013, 10:09 AM   #15
Yup. That is about the most popular topend kit there is. It's about 135 hp over stock and comes with about everything. Very complete. I always recommend this kit. I don't have it but I run those heads and they are amazing.
Old 01-20-2013, 10:26 AM   #16
Varasios's Avatar
I have a 95gt 5.0 so i guess when i do get the kit ill have to get the manifold spacer along with it
06:05 AM
