Could a 1979 mustang coupe burnout? - Mustang Evolution
Old 08-17-2009, 12:00 AM   #1
With a 2.3l 4 cylinder non-turbo? Thats only 88 horsepower... how much horsepower would a cherry bomb exhaust or glasspack add?
woolcott is offline   Reply With Quote
Old 08-17-2009, 12:06 AM   #2
bao
don't beat you gas saver. buy a real demon to play with.
bao is offline   Reply With Quote
Old 08-17-2009, 12:54 AM   #3
the 2.3l mustang is a pain to burn out with but you can achive it with worn tires. the cherry bomb exhaust doesn't give you any horsepower actually if anything it robs 1 or 2 horses away from you. its just for loudness or if you want to run a straight pipe legally.
cherry bombs were the top thing back in the 70s when drivers were making 400+hp on thier dragster cars but had to drive them home so what they did was put a cherry bomb on the car which if you look inside one its basicly a straight pipe and you can see out the other hole clearly, it doesn't build back pressure which for weak cars is a problem you need the back pressure to give you the torque to achive proper take off.
fitzsimons85 is offline   Reply With Quote
Old 08-17-2009, 01:08 AM   #4
any car can do a burnout its all on the driver. $25 bucks for the exhaust.
derwynn67 is offline   Reply With Quote
Old 08-17-2009, 01:20 AM   #5
Ford made a turbo for it up until 1988 that can double your horsepower, you won't do any burnout without one..
arrin is offline   Reply With Quote
1979 mustang
05:20 PM
