Can a ford ranger pull a car? - Mustang Evolution
Old 08-17-2009, 09:00 PM   #1
Just wondering if a ford ranger 2wd can tow a 1979 ford mustang on a trailer or tow dolly, thanks
pueblo70 is offline   Reply With Quote
Old 08-17-2009, 09:24 PM   #2
The best thing to do would be to look in your manual for the ratings for your specific year and model or, better yet, talk to your local Ford dealer.
gail is offline   Reply With Quote
Old 08-17-2009, 09:52 PM   #3
The general rule is that the tow vehicle should outweigh the trailered package by 25% (Assuming no trailer brakes). If not you can run into a number of stability troubles, namely the back end trying to jack knife on you on down hill curves in the road, severely decreased braking performance from the front end being jacked up so high. If you you can find someone to rent you a tow dolly (which I doubt because of the tow vehicle's weight) they will warn you about this. It can be done. The rental agencies in my town used to be much sloppier I pulled a couple of Saturn sl1's, a s-10 blazer with my 4.3L v6 s-10. If you can get the dolly rented I would advise you to keep your speed under realtively low at all times, even slower before going downhill or rounding a corner and if at all possible do it when it is dry.
giyn21 is offline   Reply With Quote
Old 08-17-2009, 10:24 PM   #4
It should be able to pull it just fine. Just take it slow.
I recently sold my 1980 F150 custom 4x4 and the guy came to pick it up with a 2wd ranger.
^ that was kind of overkill to be honest though.
fane is offline   Reply With Quote
Old 08-17-2009, 10:57 PM   #5
sure we pulled my friends 2000 mercury grand marquis with his 1996 ranger with no problem.
jukka is offline   Reply With Quote
10:29 PM
