How do you install the rocker arms in a 1994 Mustang? - Mustang Evolution
Old 08-19-2009, 11:30 PM   #1
I have a 1994 3.8L V6 Mustang. I have just replaced the head gaskets and such. I have never done this before, and now I am stuck with trying to put on the rocker arms/push rods, etc. What order do you have to put them in? How do you know if the valves are closed? The instructions I have don't go into much detail. Any help would be appreciated.
howahkan is offline   Reply With Quote
Old 08-19-2009, 11:33 PM   #2
wel you should have layed them in order that you remove them since the push rods are differrent lenghts you realy need to know which ones go where best you buy a repair manual but close both arm wil be same height one open wil be higher depending on where cam is at tiem your doing it youwill or should have like every other one up or down typing into search box
how to install or how to replace rocker arms really need dto know which push rod goes where first so check lenths
imported_kit is offline   Reply With Quote
Old 08-19-2009, 11:58 PM   #3
kinda did a boo boo get a haynes manual you will need it you no longer have the push rods in order.
corren is offline   Reply With Quote
1994 mustang
04:36 AM
