1995 Mustang 5.0 with cooling fan issue and wiper problem? - Mustang Evolution
Old 08-20-2009, 02:45 AM   #1
My mustang has a problem with the cooling fan. It work when it is directly wire, but will not come on when hooked up into the harness. I have no blown fuses in the panel and have replaced the relay. Is there something I am missing.
The windshield wipers also turn on as soon as the key is put in the ignition. I have replaced the turn/wiper switch and also replaced the wiper motor. Is there something I am missing?
Thanks, 1995 Mustang GT with 5.0 V8
taurino is offline   Reply With Quote
Old 08-20-2009, 02:52 AM   #2
sounds like your coolant sensor is bad should have atleast 2 wires on the sensor your looking for probably have 2 sensors one would be for the dash gauge which sometimes only has one wire and the other for your fan to know when to kick on
berke is offline   Reply With Quote
Old 08-20-2009, 03:45 AM   #3
you need to get a wiring diagram and check for short to grounds on the windshield wiper sysytem. and check for an open wire on the fan system
napayshni is offline   Reply With Quote
1995 mustang
04:38 AM
