Getting more EASY horsepower out of a 1979 Ford Mustang 302 V8? - Mustang Evolution
Old 08-24-2009, 02:30 PM   #1
Does anyone out there have any tips on how to get more than the stock 140 HP out of my 1979 5.0 L V8 Mustang?
I don't want anything drastic, just a few easy to do things to free up some of the HP thats hidden in my engine.
macray33 is offline   Reply With Quote
Old 08-24-2009, 03:05 PM   #2
use afr 185 cylinder heads and you will gain minimum 50 hp none of your other suggestions compare. then add nitrous for even more
sein is offline   Reply With Quote
Old 08-24-2009, 03:41 PM   #3
O man I know every trick on these cars. Let me tell you first of all that camshaft thats in there is the biggest reason why its gutless. Change out the cam for a performer cam and lifters. That will help out sooooo much. So lets say you did the camshaft swap. This is the other easier things to do. Get on ebay find used stock... double hump transmission cross memeber, stock h pipe, stock headers. Those would have to come off of stock 86 to 93 mustangs. Then buy a intake manifold you should sit at 240 hp.
charly is offline   Reply With Quote
Old 08-24-2009, 03:54 PM   #4
The easy to do thing would be change the carb, headers and exhauset, ignition, cold air kit, and cut the weight of the car.
camden is offline   Reply With Quote
Old 08-24-2009, 04:21 PM   #5
Headers, x-pipe & flowmasters
Dual plane intake
Underdrive pulleys
K&N filter
adir is offline   Reply With Quote
10:11 AM
