ruff idle - Mustang Evolution
Old 06-04-2008, 05:48 PM   #1
noslow5ohh's Avatar
Send a message via Skype™ to noslow5ohh
ruff idle
my car has a eradic idol goes high then low like it wants to stall then high again i changed the idol control actuator could it be the idol sensor?
noslow5ohh is offline   Reply With Quote
Old 06-05-2008, 09:40 AM   #2
Scut95's Avatar
Re: ruff idle
By idol control actuator im guessing you mean the IAC valve (idle air control)? if not try cleaning that and the mass airflow sensor and see if that helps.
Old 06-05-2008, 10:51 AM   #3
Re: ruff idle
clean the iac valve then randomly spray carb cleaner to check for a vacume leak, itll idle up if it has a leak.
SimplyOrange is offline   Reply With Quote
Old 06-08-2008, 05:32 PM   #4
silverstangboy's Avatar
Re: ruff idle
does this car have a chip as well?
93 mustang notch
~450hp 331 stroker - Sold
Old 06-08-2008, 05:44 PM   #5
noslow5ohh's Avatar
Re: ruff idle
i know it has a aftermarket ma air meter and the components to run the boost and timing i dont know about a chip
Old 06-19-2008, 05:30 PM   #6
Re: ruff idle
I too, had this problem when I swapped my 5.0 into my 79 Bronco. I had to reset the base idle, then adjust the tps. I got the instructions for this at muscularmustangs.com, and its been fine ever since.
79Bronco5L is offline   Reply With Quote
Old 07-01-2008, 07:45 PM   #7
wvstang5.0ho's Avatar
Region: West Virgina
Re: ruff idle
Ok noob ? where is this iac located Im having the same issues. Also it stays at high rpm's in between shifts, I let off the throttle to shift and it stays where it last was.
wvstang5.0ho is offline   Reply With Quote
Old 07-01-2008, 10:49 PM   #8
Scut95's Avatar
Re: ruff idle
The IAC is located on the throttle Body.....there's 2 bolts that hold it in, an electrical connection and there is a gasket on the other side so try not to lose it. Most Mustang's RPM's hang up a bit when shifting....does it hang for a second and then drop or does it just stay there no matter what?
Old 07-02-2008, 06:43 AM   #9
Re: ruff idle
Ok great thanks for the info, yes just hangs there a few seconds, first Mustang so Im new to how they run and react. So thanks alot, any suggestions on how I go about cleaning it and the TB. thanks for the help.
Old 07-02-2008, 08:40 AM   #10
Herbstang's Avatar
Re: ruff idle
The RPM highing can be corrected with a tuner .you need to adjust the RPM decay rate ford set it up this way to burn off excess fuel
Old 07-02-2008, 01:10 PM   #11
Re: ruff idle
Great thanks, I was looking into getting one, what is a good one to get for a 94 GT ?
Old 07-02-2008, 09:01 PM   #12
Scut95's Avatar
Re: ruff idle
Take the motor off and spray in brake or carb cleaner....basically you can only spray in, so just try and get everywhere in there and then let it dry out a bit.....the throttle body, spray with TB cleaner or brake cleaner and you can use a tooth brush to scrub the carbon and dirt out. Thats what we so at work atleast
Idle Problem Help!! W225110 1979-1995 Mustang GT 7 03-30-2010 07:12 PM
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 07:44 AM
Unsteady Idle Ibanezplayer272 1979-1995 Mustang GT 21 06-04-2008 06:33 PM
how much vacume at idle initialb 1996-2004 Mustang GT 2 08-03-2006 10:54 AM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
01:15 PM
