1,800 to 2,000 RPM idle in neutral - Mustang Evolution
Old 06-04-2008, 10:18 PM   #1
Mercedez L.'s Avatar
Thumbs down 1,800 to 2,000 RPM idle in neutral
What could be the cause of this? I have already had the coolant sensor changed, the ACT sensor changed along with PCV Valve, PCV valve mesh. Sometime ago i cleaned the IAC and throttle body but this time it didn't work. Could it be that I need a new IAC? Could it be from a small anti-freeze leak from waterpump gasket?
This is for a factory 1988 Mustang 5.0 GT.
2: Well the problem went away for a few months now with the weather change it has returned.2:
Mercedez L. is offline   Reply With Quote
Old 06-05-2008, 08:20 AM   #2
Re: 1,800 to 2,000 RPM idle in neutral
you checked the timming to see how its set
Old 06-05-2008, 08:37 AM   #3
MonteCitan's Avatar
Timing advance should be between 8 and 14, much different from that could cause idle issues
My 89 would 'stick' or 'hang' at 1200-1500 quite often, after replacing the IAC it was fine for about a year then started doing it again... wouldn't hurt to try a new IAC... Idle set screws should be fine... try the idle relearn procedure...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-05-2008, 11:00 AM   #4
is that you in the avatar? if so ill just fly over and take a look for ya
SimplyOrange is offline   Reply With Quote
Old 06-05-2008, 01:30 PM   #5
Herbstang's Avatar
Book Rob and myself a seat
Old 06-05-2008, 01:31 PM   #6
Yeah, someone will need to supervise that youngin....
Old 06-05-2008, 10:36 PM   #7
Question Re: 1,800 to 2,000 RPM idle in neutral
It's at 11 degrees where it has been for many many years before this idle problem came along.
Old 06-05-2008, 10:38 PM   #8
ntopic:
ntopic::feedback:
Old 06-05-2008, 10:40 PM   #9
I was thinkin of getting a new IAC as I have already cleaned t his original IAC and throttle body but it didn't help this time. I believe LateModelRestoration sells it for $89.95 and hopefully it is a Ford part.
Old 06-08-2008, 02:32 PM   #10
silverstangboy's Avatar
just pick one up at your local auto-junk parts store. I think thats going to be your best bet, sure sounds as if your IAC/IAB is hanging open... they will be cheaper than 50resto.
can I ask another question though? why is your base timing set at 11?
93 mustang notch
~450hp 331 stroker - Sold
Old 06-09-2008, 02:45 PM   #11
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Originally Posted by Mercedez L. View Post
ntopic:
ntopic::feedback:
oh wow.... rob, herb, and jarod... good god i never seen someone get shutout so quick lol
QUICK!!! PURGE THE NOS! lmao
Cajun JungleBoy is offline   Reply With Quote
Old 06-10-2008, 12:18 PM   #12
Herbstang's Avatar
Then you should have been at Joe Wheeler
Old 06-10-2008, 12:29 PM   #13
Yeah, no kidding....
Then again, I wasn't talking about her anyhow so...it doesn't matter to me. I was referring to the youngin' Jarrod....
Old 06-10-2008, 01:04 PM   #14
ppsshhhht...ppsshhhht, hey ill drop it when i find out the answer to my question.
i aint no youngin'
yea just buy one from auto-zoo or something...sooo is it you or ur girlfriend???
i have around $800...wat shall i get next? 98MustangGT 1996-2004 Mustang GT 12 07-20-2007 09:50 AM
800+whp Bronco to Mustang questions new project jeffhart_99 1979-1995 Mustang GT 17 10-15-2006 12:08 PM
High RPM idle electricstang Pre-2005 V6 Mustang 4 09-25-2005 12:55 AM
Reving while in Park or Neutral? Ibanezplayer272 Pre-2005 V6 Mustang 12 05-31-2004 01:15 AM
Turn $ 6 dollars into $800,000 dollars NO BS ! ERICK The Bar 18 03-25-2004 09:55 AM
06:41 PM
