Notchy MGW Shifter and Super Stiff King Cobra Clutch - Mustang Evolution
Old 06-10-2008, 08:38 AM   #1
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
I was told that the cable is split at the end, resulting in me having to press extremely hard on the clutch, and weird shifting:
1-2 is very notchy and difficult, 2-3 isn't to bad, 3-4 is smooth as hell, 4-5 is similar to 1-2. reverse... ugh hard.
And this is with an MGW Shifter...
How could I go about fixing that? Anyway to fix that without having to buy a whole new cable?
Cajun JungleBoy is offline   Reply With Quote
Old 06-10-2008, 08:41 AM   #2
Re: Notchy MGW Shifter and Super Stiff King Cobra Clutch
actually, your cable liner is unwinding on the inside making it difficult to push in, i think you need a new cable and a firewall adjuster, i may be able to make it easier to push in with just a simple adjustment under the car.
SimplyOrange is offline   Reply With Quote
Old 06-10-2008, 08:44 AM   #3
When would be a good time to stop by? Think you could show me how to do some of the simple things? Also, I REALLY need to get my steering problem fixed.... badly.
Old 06-10-2008, 08:50 AM   #4
at7311's Avatar
Send a message via AIM to at7311
Whats up with your steering?
at7311 is offline   Reply With Quote
Old 06-10-2008, 08:53 AM   #5
Rob thinks its the Steering Rack/Column.... few other people think its a bushing. Me... I have no clue. Just I can turn it about 45 degrees left and right and get no response.
Old 06-10-2008, 08:59 AM   #6
at7311's Avatar
damn that blows. Is that expensive to get fixed?
Old 06-10-2008, 08:59 AM   #7
not from what I've been told...
Old 06-10-2008, 09:02 AM   #8
Ill have to look at the steering, most of its set up with u-joints so its probably the steering rack.call me today after 5
Old 06-10-2008, 09:15 AM   #9
Ugh...Didn't we already answer these questions this past weekend?
And, for those searching later, it is not the MGW that is notchy, it is the pile o turd cable he has on there which was discussed this weekend...and restated in this thread by the person that discovered the problem.
As for the steering, I read once upon a time that there is some rubber in there....in fact, here is a quote for you...and the solution to your problem
You can sharpen your Mustang’s steering response with this solid steering shaft assembly. With your stock steering shaft, motion is lost due to the flexing of the rubber rag-joint. This flexing usually feels like play in the steering wheel (you can move the steering wheel without the car changing direction). The factory joints are replaced with race-quality needle-bearing U-joints, resulting in a dramatic improvement in steering response.
And here is the link to the part to fix it if you went aftermarket, or you can find another stock steering shaft.
Steering Shaft Assembly, 1994-04, Power Steering Rack [MMST-14] - $249.95 : Maximum Motorsports Performance Mustang Suspension Store, Buy Now!
Old 06-10-2008, 09:20 AM   #10
i'm just gauging to see what others opinions were. I'll be going to TPS anyways
Old 06-10-2008, 09:21 AM   #11
plus, there can always be someone else with the same question trolling, and see this thread now
Old 06-10-2008, 09:31 AM   #12
ive never tackled the steering problem but i trust robs input, i think thats going to be the issue. im still trying to find out why they put the duct tape mod on the quadrant
im diagnosing it as the cable because my steeda cable did that to me so i put a 04 cobra cable and used the steeda quadrant and firewall adjuster and its been butter ever since.the pressure from the performance clutches make the metal liner on the inside to start to stretch, oem is the best cable on the market.
you and kyle should just call rob "DADDY" lmao
Old 06-11-2008, 02:04 PM   #13
i've debated that... lmao
thanks for fixing my clutch yesterday and the other problems
Old 06-11-2008, 02:07 PM   #14
no problem.
Old 06-11-2008, 02:09 PM   #15
hahah... papa rob
MGW shifter JerryK123 1996-2004 Mustang GT 5 03-31-2010 07:02 PM
King Cobra Clutch - Yea or Nay ? Jeff2000GT General Mustang Discussion 9 03-23-2009 03:49 PM
Another new MGW shifter install thread bbunt302 1979-1995 Mustang GT 2 01-19-2006 10:38 PM
Newest MGW Shifter! Matt@StangMods The Bar 18 08-23-2005 03:40 PM
what MGW shifter to buy? Sublime782 Pre-2005 V6 Mustang 3 06-13-2005 03:52 PM
07:36 AM
